Turn off pdc octavia fl
Hey
I want to turn off parking distance permanently. I hate it :)
I cant find it vcds
If you have Maxidot it's one of the options.
if you don't have maxidot then the controller will have to be coded out.
I find it VERY useful! (Rear only though)
What is it that you don't like?
is there not a quick way to turn it off each time if needed - my old car had a pdc kill button.  I use a bike rack frequently, so it sends the pdc nuts and I can't find a quick way to stop it.
Not the biggest problem - had the car about a month and it's the only negative I can find!  Can't believe what a good car the vrs octy is, beaten all my expectations...
Do you not use a light board on the back of the bike(s)?
When coded correctly the parking sensors are turned off when a light board is plugged in.
There's only a 'kill ' switch fitted if front sensors are also fitted.
It also acts as an 'on' switch in case you happen to be approaching a parking space forwRds without having gone backwards first.
Pull the fuse? Im sure your local auto electric place could run you a switch pretty easily
I fixt it now. Coded it out with vcds but it beep when i put in reverse gear
So i tok the module out from trunk
Thanks guys :)
U do realise u can turn pdc volume right down so all u get is the visual!
Yes i do that but the volume is on anyway
Turn off pdc volume in stereo, nothing hapend, coded it with vcds, nothing hapend
So i got the module out and now its all off :)
You haven't said why. Just curious
I dont need it, it sounds when it rain snow
I hate it sound when i put in reverse
I was going to replace my car if it failed to remove pdc :)
But i love my skoda octavia 1.6tdi -10 :)
I drive very much, its cheep to own
you have a faulty sensor if its on all the time when you are in reverse.
I works okej when its sunny but when its water or snow on sensor it sounds in revers
But now i throw it out:)
As above you have a faulty sensor which is letting in water. Easily fixed.
Hope you haven't really thrown the module out. They aren't cheap, and when you sell your car the buyer may wan the sensors working.
But i vcds it dosent show any fault on sensor
It beep when its water on sensor but when i take a paper clean it off the beep stopps when i have revers gear in
Ofcourse i have the module i only disconect the contacrs
What you see on the bumper is just a cover for the sensor. Water can get in between the sensor and the front cover. It is a common problem.
Aha thanks :)
