Have I just had a limp moment in the vRS
Had been for a run to Atherstone and back today, very wet in places, but nothing remarkable otherwise
A lot of you may know the road where you turn off the A1 at Markham Moor to head towards Lincoln, and head up a sharpish hill
I went up, overtaking another vehicle in the process, and the power hesitated, an engine fault blipped up on the dash, and the coil light illuminated and stayed on, with the speed limiting itself
I pulled in fairly shortly afterwards in a lay-by, switched off, re-started, and everything operated properly for the rest of the journey, no more lights, pick up was fine
Have I just had one of 'those moments', or does it need looking into any deeper?
I'm going to do a fault code check, which might throw something up, but the fault seems to have cleared itself
All assistance gratefully received
Hopefully
I hope it is not the injector woes. Warranty work can be as bad if not done right
Scan it and see - If the CR170 uses the same turbo control as the PD140 it could be sticky vanes causing an overboost, but if you got lights there should be a code in the ECU.
A generic OBD2 code reader should be able to read the ECU at least if you haven't got access to VCDS.
Paul
VCDS scan done this morning..............faults cleared, I'll see how it goes next time out
Address 01: Engine (CEG)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 HF    HW: 03L 906 022 GA
   Component: R4 2,0L EDC G000AG  5762
   Revision: --H01---    Serial number: SKX7Z0H632B0F8
   Coding: 0000078
   Shop #: WSC 00191 264 15243
   VCID: 70EA4C7B639C4298D0B
3 Faults Found:
009299 - Diesel Particle Filter; Differential Pressure Sensor
               P2453 - 000 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 60102 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:54:40
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Voltage: 12.31 V
                    Pressure: -51 mbar
                    Pressure: -41 mbar
                    (no units): 0.0
                    Temperature: 51.3°C
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 60108 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:28:11
             Freeze Frame:
                    RPM: 1265 /min
                    Speed: 63.0 km/h
                    Voltage: 13.98 V
                    Pressure: -51 mbar
                    Pressure: -41 mbar
                    (no units): 117.3
                    Temperature: 22.5°C
000665 - Boost Pressure Regulation
               P0299 - 000 - Control Range Not Reached - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 60325 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:23:53
             Freeze Frame:
                    RPM: 3404 /min
                    Speed: 105.0 km/h
                    Load: 100.0 %
                    Absolute Pres.: 2601.0 mbar
                    Absolute Pres.: 1774.8 mbar
                    Lambda: 65.5 %
                    Lambda: 65.5 %
Be interesting to see which one comes back, is that DPF sensor error code the one that you get when you have the dodgy original one installed, there is a revised version for the CR.
Turbo control range not reached could point to a Turbo issue or Boost Leak somewhere.
Thanks for that...........I'll keep a close on it to see if/when anything similar recurs
