TPI 5mm spacers (5x112 and 5x100)
5mm centric spacers
5x100 and 5x112 fitment
£25 posted
Ok to use standard bolts?
Hmm, I used stock bolts with 3mm shims but I could tell I was already a turn short of normal, even though there was a lot of turns.  I am not sure I would fancy being 2 turns out.
YEA OK TO USE MATE,
jASE IF YOU LOOK AT THE ENDS OF STD BOLTS WITH STD RIMS YOU WILL SEE ABOUT 5MM THAT IS RUSTED AS THAT GOES THRU THE HUB SO YOU HAVE THE 5MM POKING OUT THE BACK OF THE FLANGE
sorry for the caps, was playing COD lol and hit it.
ne way using these means the bolts still go all the way into the hub flange, just means they don't poke out the back like normal.
If the above is the case, then fine.  Never seen how far a stock bolt goes through the hub, or how many turns a hub has in it. :thumbup:
  • 5 weeks later...
Bump
£25 posted
  • 2 months later...
Still got these
PM Sent
Sold cheers mate
