VCDS /Bluetooth Coding Help - Manchester Area
I`ve just retro fitted my bluetooth module and wiring loom and microphone after picking my 2012 VRS up from a dealer in bath.
I took the module with me when I picked up the car and asked the technician to simply remove the belero headunit connect the module and microphone and code and then remove and I would route all the wiring looms when i got home etc.
The so called Technition didn`t have a clue about bluetooth retrofit but said he would activate it for me.
Now that I`ve returned home to Manchester and fitted all the wiring and module, guess what its not working !
The belero recognizes that a BT is attached as there is an option for emergency call and BT audio is greyed out in the media section.
I guess that its just needs coding ??
Anyone confirm this to be the case ?
Is there anyone you would recommend in the Manchester area that can assist ??
I work office hours in Middleton if that's any help?
Thanks so much for the offer. I can meet you wherever and what ever time it suits you.
