3C8035730C Bluetooth module, Bolero and no maxidot HELP !
Has the maxi dot always been white? If it was ever red like the VW version that also has some Bearing on module options! It is very confusing!
Bolero-wise, the 'M' variant is the one that's more compatible apparently.
Mine's the white type, came with a good spec really tbh.
I am just fitting this part. Where did people stick the flat phone aerial? Also do you need to chop wires or just plug in the adaptor as is and it is onto the stereo. 2010 Bolero with maxi dot and mfsw
Thanks a bit confused
I don't have the answer but had been wondering the same thing about the aerial / antenna. All the paraphernalia I have read from people selling these things suggests no wire cutting is involved. Should be plug and play. I guess you'll be able to confirm that to the rest of us.
I will test it before I put it back together. Make sure you buy the special trim pullers they are brilliant and don't scratch anything.
