anybody know anything about CNC RS232 connections
Hi at work all the CNC's are connected either by ethernet or using RS232 connections to a bespoke system
I need to get a program off one of the old machines that is not setup
i want to plug a laptop into it and send the program to the laptop via the serial port
what software can i use to receive the file from the machine
i take it i can just plug it in start the software and send the file from the machine
not really had tto do anything with the CNC's so am a little lost
the bloke that set it up left and lest absoloutley nothing on how the system is setup :thumbdwn:
It's many a long year since I last worked with CNC machines. I seem to recall that some of them used weird codes for flow control.
You'll need some kind of data capture program to read the serial port. I used to use Kermit many years ago, but I'm not sure what's available these days.
Not much help, am I?:o
Phil
And Kermit/xmodem/ymodem/zmodem (or others) will only work if that's how the machine is sending the data. You need to look at the menus on the machine and see if any of them offers data sending "options". If it's any of the aforementioned, Hyperterminal (free with most flavours of Windows) supports them all.
HTH
Hyperterminal - best option on windows by far
thanks i will give it a try tomorrow
only pain is all the laptops i can lay my hands on none have a serial connection unless you use the docking station
bloody USB ;)
oh well
We have the same problems as we need serial ports as work and there aren't too many machines that come with them now.
You may as well get Hyperterminal Private edition from www.hilgraeve.com as it's more stable than the version included in windows.
