Speedometer dips and cutting out
Hi just bought a 2010 Octavia automatic diesel.2.0TDi problem  with the dipping speedometer needle as it usally shifts gears with it.Some times it cuts out on the road at speeds.Wanted to change the Vehicle speed sensor not able to find it on the transmission.Can somebody help please.
Can anybody help !
You need a scan done with VCDS. Post your results up here and someone may be able to help you. If you do not have VCDS then ask another member who has it who lives near you - most will be happy to help in exchange for beer tokens
Hi thank you very much.Will find the fault codes and let you know.
