Octavia 2 centre console/arm rest/box
Has anyone retro fitted the oem centre console arm rest/box to their car??
mine has the standard ambiente type thing with spaces for cups etc
however I want to fit the arm rest type console and was wondering what 'other' parts necessary other than the main console/arm rest itself as ill be getting parts from a breaker miles away...
cheers in advance
I've got a brand new one in the box, I'll have a look when I get home to see what the fixings are like.
Will this help you?
That's be great thankyou
Just want to make sure I get all I need sent with the new one
It looks to me as the arm-rest is a separate part of the arm-rest consul (i.e. it's the frame that holds the rest tilt and lock piece).
There are 4 holes at the base of the frame which I assume screw to the floor or maybe Torx bolts.
The compartment below the rest is where bits and bobs are placed, this is the 2nd part of the arm rest so make sure you get both bits + the pipework for the A/C flow.
There are a few tutorials on here for the process of fitting it, with pictures.
There are also discussions specifically about air ducts and fitting these.
Simon TDi Sport has retrofitted this to his Sport, so he'll be able to assist as well.
See guide in my sig.
Really good job fitting that box in that guide!
