Felicia Fuse Point Bd9 Location - Big K Q
BigK
I am in the last stages of fitting the Skoda accessory kit to provide central locking to my Felicia 1998, the power +ve for the control uinit is a red wire and the instructions say remove connector BD and fit to BD9, any ideas which plug on the fuse board is BD and which pin ins 9?
Also the latch motor lever seems a bit short to operate the release - are ther different locks for the Felica with differing lenght operating arms? mk 1 and 2?
Just got to reasemble the rest of the car then......
John
After doing a handstand on one hand and pulling out all plugs on fuse board I located the pin and plug with the aid of a meter,
its the far right small green plug and the pin is the bottom righthand pin. Its connected to the normally spare fuse no 18.
If any one wants to remove the cable plugs remember to release the botton clamp that releases all lower plug holdings the tops are released individualy.
How my arms ache now - :(
John
don't you know that you can remove the fuse box from the mountings to let it dangle free then :rofl: :rofl:
I do now!!!!! any thoughts on the hatch lock??
latch lock or hatch (boot lock) ?
The latch lock I guess the actual part that hold the hatch.
The central locking servo assembly is mounted on a bar between the two strenthening points on the hatch panel. On the latch mechanism is a sloted curved elongated hole that a lug is attched for the setvo arm fsupplied in Skodas kit, the position of this arm is not correct and seems too short for correct operation of the central locking pivoted servo arm.
Good job I know what I mean :rolleyes: any clearer??
