Lowering Springs
Know dought this has been disgust before and yes I have been reading various articals on this subject but I'd like to clear up a couple of points please " I am thinking of lowering my Furbie vRS. Will spring alone do or do I need shockers aswell " :confused:" Does It tighten the car up " Is it really worth it for every day use? " Any advice would be appreciated.....Andy
'Know dought this has been disgust before and yes I have been reading various articals...'
:rofl:...No dot this has been dizgust...? :rofl: Did you do that on purpose because I'm really crackin' here :rofl:
Spelin int me stroge pount
Personally, if you can afford it, I'd opt for the Eibach spring and damper combo. Both designed to work together, very little day-to-day comfort lost but significantly improved handling and braking.... also doesn't look "slammed".
Chris
Personally' date=' if you can afford it, I'd opt for the Eibach spring and damper combo. Both designed to work together, very little day-to-day comfort lost but significantly improved handling and braking.... also doesn't look "slammed".
Chris[/quote']
:iagree: :D
Chris[/quote']
Any Idea on price Chris Plus fitting of course.....I know what a spanner looks like but.............................................. :confused:
Yeah right...you got the easy words wrong and the hard words right...:rofl:
You just missed a group buy for them which Ade organised with the option of getting them fitted at Jabba. Got mine about a year ago and I think it was about
You may get lucky and be able to hijack the GB if you ask Adrian or call Jabba cause they struggled to make the numbers.
I ran only springs on my Saxo VTS for a while without problem.
When using only springs you must be prepared for greater wear on your shock absorbers and they will need more frequent replacement.
The springs are shorter than the standard set up but you will still be using the same length of shock absorber.
