Hi, I wonder if anyone can help...I recently replaced the high level brake light on my 2003 octavia estate, and since then, when i operate the rear wash wipe, there is a dribble of water dripping onto the boot cover...i've removed the light unit and checked the fiiting is tight, and it appears to be, and i've even tried securing it with tape, to no avail! I'm starting to wonder whether there should be a rubber seal which i missed when removing the old unit....any advice out there? thanks, Ian
There will be a join in the water pipe  near the top left corner of the boot under the panel trim that likes to work its way loose, especially if you've been moving the electrical cables of your lights.
Check that the join is popped together. Unless you mean you can see it dribbling down inside from the nozzle end?
Edited by Octyvrs03
