Columbus Satnav Disk
Yes mine was an A, they were built up to end 2008 or thereabouts I believe and I agree there aren't too many users (on here at least) with them.
  • Replies 55
  • Views 4.5k
  • Hungry Horace
    Hungry Horace
    Did as you suggested and sticker reads as follows Part number on sticker is 3T0 035 680 HW: H11 SW: 1164
  • As kb says updated, but its not that new. Check out www.rnsfirmware.com and take the 'modified for older units' route. Adam
  • Yes mine was an A, they were built up to end 2008 or thereabouts I believe and I agree there aren't too many users (on here at least) with them.
Ok I just enabled test mode in VCDS (didn't realise it needed hard reset after).
Delivery part no. 3T0035680A
HW ver. H11
SW ver. 1304
Map ver. 7920
Can you get the HW Radio Version?
If it is 0004 you have a Rev B unit.
Sent from my phone so please excuse brevity and spelling
Thanks again for the replies.
Just checked and Radio HW is 0004 so it's a revision B.
So I am thinking firmware 4024 modified is latest I can go to.
Not sure there is any benefit going past that anyway, if that has radio text you don't need to go any further.
If andyvee is correct and yours is a revision 'B', then you won't need modified firmware.
Yes agreed if you are a revision B, you just need the standard firmware. 402x does not have radio text, so 412x would probably be a good option in your case.
That is what I was running on mine, and it was HW03.
Thanks again everyone. I updated to firware 3974 and everything seems to be ok (might go to 4xxx later)although I noticed I cant turn the radio on now without turning on the ignition 1 click.
Also did a scan afterwards and have a host of errors appearing with the radio etc. Would this be because of the firmware update and is there something I need to do that I have missed. Thanks again to everyone that has helped me you have all been brilliant.
Scan results 2 posts below
Edited by Hungry Horace
Clear your error codes and then rescan - doesn't appear to be any issues from what I can see other than the fact that the Columbus was upgraded.
You have the optional sound system, nice.
Can you post the results of that scan keeping the formatting intact?
This is the second scan. I scanned it cleared them then re-scanned and this is the result. Don't know what happened to the formatting previously.
Sunday,08,December,2013,21:02:29:10074
Chassis Type: 1K0
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 47 52 55 56 62
          69 72 77
VIN: xxxxxxxxxxxxxxx
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CEG)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 RE    HW: 03L 906 022 GA
   Component: R4 2,0L EDC G000AG  4874
   Revision: 13H01---    Serial number:
   Coding: 0000078
   Shop #: WSC 46396 133 11833
   VCID: 79FDE9D74949
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 051 T    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1909
   Revision: 04844002    Serial number: 00000904241244
   Coding: 0000020
   Shop #: WSC 73430 790 00999
   VCID: 2443E8A39E4B
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 143B601C09220003281106ED901F0042AD00
   VCID: 800B0433AA93
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 AL    HW: 3T0 907 044 AL
   Component: Climatronic   H14 0302
   Revision: 00004001
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_Climatronic_SK35.rod
   VCID: 7CF3F0C3467B
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0537
   Revision: 00103 AC
   Coding: 40180AB8F00508C040080080110011E4037000AE626D8560E40440040000
   VCID: 326F1EFBD4BF
   Part No: 1Z1 955 119 C
   Component: Wischer 25050  22  0601
   Coding: 00D7B7
   Part No: 1K0 955 559 AH
   Component: RLS 260509 05  54  0402
   Coding: 0730ED
1 Fault Found:
00907 - Intervention load Management
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 109434 km
                    Time Indication: 0
                    Date: 2115.14.19
                    Time: 20:59:51
             Freeze Frame:
                        Term 15 On
                    Voltage: 9.95 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475.clb
   Part No SW: 1Z0 919 475 C    HW: 1Z0 919 475 A
   Component: PARKHILFE 8K  H06 0006
   Revision: --------    Serial number: 66540913902689
   Coding: 010102
   Shop #: WSC 46396 133 56265
   VCID: 418D41376119
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2DN37B
   Coding: 0020790
   VCID: 3D753DC71DE1
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           055 0111
   Coding: 0001832
   VCID: 76E7E2EB7857
   Part No: 3T0 959 537 A
   Component: E221__MFL-URO   H07 0011
   Coding: 00000131
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 843 E    HW: 1Z0 920 843 E
   Component: KOMBI         H21 0109
   Serial number: 00000000000000
   Coding: 110F00
   Shop #: WSC 73430 031 00999
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 3A7F36DB0CCF
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 0222
   Revision:   H16       Serial number: 4020K095230862
   Coding: EDA17F46500602002302
   VCID: 66C7B2AB28F7
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H21 0109
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
   VCID: 3A7F36DB0CCF
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 B    HW: 3T0 035 680
   Component: RNS-MID       H11 3974
   Revision: AB001001    Serial number: SKZ6Z7J8145047
   Coding: 04060000000000830000
   ASAM Dataset: ------------------------- ------
   VCID: 2F69178FC78D
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2107
   Coding: 0004342
   VCID: 76E7E2EB7857
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 74     2901
   Revision: 00H15000
   VCID: 2F69178FC78D
Address 47: Sound System (R12)       Labels: 3T0-035-456.clb
   Part No SW: 3T0 035 456     HW: 3T0 035 456
   Component: KonzernAmp10K H06
   Revision: --------    Serial number: BP218290404136
   ASAM Dataset: EV_AudioVerst10KanalBNO2 A01003
   ROD: EV_AudioVerst10KanalBNO2_SK35.rod
   VCID: EED74A8B8007
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Component: Tuer-SG         009 2113
   Coding: 0004342
   VCID: 489B5C134223
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revision: 00H04000    Serial number:
   Coding: 1507354
   VCID: 346318E32EAB
   Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000023
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000023
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   VCID: 2F69178FC78D
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 326F1EFBD4BF
Address 69: Trailer        Labels: 1K0-907-383-MY7.lbl
   Part No SW: 1K0 907 383     HW: 1K0 907 383
   Component: ANHAENGERELEKTR 003 0020
   Coding: 0000001
   Shop #: WSC 00000 000 00000
   VCID: EADF469BBCEF
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33611BFF2BA5
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 5N0 035 730 C    HW: 5N0 035 730 C
   Component: J412                8506
   Revision: 00019000    Serial number: 0000A07949606
   Coding: 0020121
   VCID: 285BFC93E263
End   ---------------------------------------------------------------------
So the only fault code refers to the Load Management on the CECM. I'm not sure what this is, as haven't come across it before. All the other modules are clear.
Think it might be a battery issue, and if it is the original on a 2009 car, not entirely unexpected by my previous experience...
http://wiki.ross-tech.com/wiki/index.php/00907
Try charging the battery!
Its odd as the first part of the scan is showing errors, but when you look at the actual detailed info there is no error apart from the one you mentioned.
Beat me to it!
My guess is loads of scans and a firmware upgrade have flattened the battery a bit ..........
Sorry posted before seeing the other answers. I will check the battery out. Only picked the car up yesterday and its been sat in the showroom for 6 weeks so maybe battery is a little low.
Also any idea why the initial part of the scan is showing errors?
Not at all, VCDS will have cached the errors from the first scan before you cleared them.
Go for a drive and see if any come back in the next few days, but if you can trickle charge the battery overnight it might be a good idea.
And I'm only at 6 words a minute single finger typing!!
Horace: if you clear the modules individually rather than using the clear DTCs option, I think it prevents them showing up at the first part of the scan.
But they are clear it seems.
All related to when you updated the firmware and the fact that VCDS caches them between autoscans.
Same here from my phone LOL
Thanks for the answers. You guys are a fountain of knowledge. Will try to charge up the battery, also got a 500 mile trip on Tuesday so will scan again after that and see what it says.
No problems, hopefully a charge and a good run and all will be well after that.
And the saga continues. Firstly battery was flat this morning so I think your right and that's what's giving the errors.
This morning I went into the secret menu on the navigation and it is telling me the hard disk only has 2 partitions, I was under the impression it should have 3 once I upgraded firmware to 39xx.
Also the satnav is stuck in a location far away from me and it won't locate on my present position, is there some sort of reset I need to do. I have tried the < > and i buttons but is hasn't made a difference.
Wonders if the Columbus is causing battery drain and also suffering from Regensburg syndrome (or simply a duff GPS antenna)?
If so, this would suggest that a modified firmware is needed and the Columbus is a revision 'A'...
Might be worth trying the CANBUS fix for older gateways at the bottom of this page or trying to reinstall the 38xx firmware as (IIRC) this was the one that many people stated needed to be used in order to correctly establish the three partitions before upgrading further (although in my experiences, this was a false assumption).
CAN Gateway is Rev AA though so shouldn't be suffering from battery drain.
If it is radio HW 0004 it isn't a Rev A.
