LCR Steering Wheel? Cut off?
Its meant to be all black with red stitching
Its common for the perforated bit to rub through to red :(
Still got it for a good price
To remove the airbag you use a flat blade screw driver throught the 2 holes in the back of the wheel + wiggle untill it releases
Then remove the bolt attaching it to the column. Will either be a big bolt of a multi- spline
Your Skoda VRS airbag will fit straight on ;)
Yeap, its supposed be all black with just the red stitching and red line across the top.
Looks good actually, what products did you use?
Ebay
Just typed in leather dye. Comes in maybe a 50ml bottle with a foam applicator! Bests a retrim for sure
