Octavia Mk1 relays
Hi,
Kindly can anyone tell me Skoda Octavia Mk1 99 relay location and type related to ignition system.
BR
Farooq Ahmad
Edited by Farooq Ahmad
Relays are behind the trim below the steering wheel.
Hi Freedom
Thanks for your reply. How can I check if they are working fine.
What problems are you having? Is your call petrol or diesel?
It is Petrol one. Actually when i try to start the car. It turns on all lights but car does not start. I try twice or thrice and it works then it runs perfectly. However it happens only 3 out of 5 times. It was a battery problem one week ago so i tried to start it log of time and i think it may be some fuse or relay that is creating this problem due to lot of tries in starting up.
You would be best off getting the car scanned for fault codes. Look in the Diagnostics/VCDS forum on here, there is a thread with a list of people who could scan the car with VCDS and see if there are any faults.
