Get your beads out
Thanks for posting this observation Mr.G
Dirt tends to lie over the wax surface...What this does is visually affect the behaviour of your chosen LSP
When this thin layer is removed by washing, it exposes the layer to the elements again
Obviously this wont continue for ever, but that's why you see this
Not sure on that exactly Chris, don't think the top layer washes away to expose a fresh layer of was with reinvigorated beading; a layer of bonded wax is so thin. But I did see a decent post the other week on DW. I know you're not a fan of it, but check out post #8 from Dodo Juice as to why beading diminishes.
http://detailingworld.co.uk/forum/showthread.php?t=369665
  • Replies 2.1k
  • Views 150.3k
Thanks Neil
I am sure this is why  ...... I see it all the time...problem being though..washing naturally degrades the LSP eventually as well.
After a wash the LSP starts to bead again ...Why?...... because the dirt was preventing the hydrophobic action from working as well....I'm very surprised you've not seen this
You directed me to DW..so I read this:
From DW (DodoJuice reply:)
Initial beading will diminish after 2-4 weeks due to a build up of dirt.......
Nothing else Ive read there makes me change my advice Neil..Washing refreshing the surface..It just does!
The poster there on DW used Prima Amigo (A Glaze) this, it was suggested, caused the LSP to diminish early..Yes..Ive seen that too..Wondered why TBH...
In this case though, no glaze was used..nor do I use a glaze on my cars or clients' and yet the initial beading falls off after a few days and then after a wash it returns
Your views? I'm prepared to have your opinion or better still, your experiences
@Samuir...You've clicked the 'like' button on Neil's Post......Can you explain why?
I assume you agree with his comment..You're quite entitled to do so
BUT
Why?
Do you have a comment on this LSP behaviour yourself?
If my observations are wrong, I would like to hear from you as well.
Sent from my SM-G925F using Tapatalk
Thanks Neil
After a wash the LSP starts to bead again ...Why?...... because the dirt was preventing the hydrophobic action from working as well....very surprised you've not seen this
BUT
Why?
I read on the DW post that the glazing oils within the wax evaporate after 4 weeks or so, not the glaze beneath, therefore the beading ebbs slightly. All waxes contain oils to add gloss. If what you are saying is correct, then a crust forms on the layer, preventing those oils from leaving, then that upper crust is washed away? That would take some really "Nano" particles surely?
I'm just saying that washing doesn't remove a layer of wax to expose a fresh layer of wax, I'd be interested to know your source for that information. I'm not a chemists, but understand the basics of chemical bonding from my job background.
Of course, washing will remove loose dirt on the surface to freshen beading somewhat, but the wax will age as a layer, lose it's initial beading capability due to the lovely oils that cause epic beading diminish throughout the whole layer of wax and contamination will build up. Otherwise with those really durable chemical resistant waxes would age and not wash away, but the beading would be horrendous?
Just questioning the chemical logic behind the statement brother, it's not a personal attack.
I'm sure Ste was just appreciating the link. He probably believes that, as I believe, Dodo Juice are a reputable company producing decent waxes, whom I'm sure understand the whole bonding process and what happens to their waxes as time takes it's toll. I wouldn't read into it too much buddy.
Very nice Karl!
Nothing scientific Neil
Just observation
I'm not suggesting that washing removes a layer of wax to expose another...just that washing removes the dirt that is preventing beading of the wax or lsp..that all I have ever said
Just observation
That's the way I read it. Perhaps the first use of the word 'layer' in the one sentence suggested some wax rather than dirt.
When this thin layer of dirt is removed by washing, it exposes the wax layer to the elements again
I can see that Nick...I should have said 'layer of dirt'
I'll clear this up as Chris isn't.
What Chris originally put is that washing removes a top layer of wax, an upper crust of contaminated wax, that will reinvigorate the beading. That is factually and scientifically incorrect. So I stated this with my above post.
Chris then went back and edited what he put to read that removing dirt does this after he had been away and "checked his facts". Which is factually correct and is now making out that I misunderstood his post, which I didn't.
I have no idea why Chris can edit his posts without it showing, or indeed I cannot understand why he would need to edit his posts to change his statement only then to make out that I have misunderstood his statement. It is very strange behaviour, but I just wanted to set the record straight. I am not being argumentative or picking a fight as it seems above. But if someone tells you "the world is flat" I will correct them, even if they are then able to go back and tell you "the world is round" by editing that post without you being able to see that they have edited their post.
Neil
Neil
I have communicated with Neil what had happened via PM..He now understands
I edited my posts because he read them wrongly...or I wrote them badly...That's the reason I edited it, not to go away and research or deliberately disagree with him
I changed it to read as follows:
All sorted out amicably ...as it should be ...Just a misunderstanding
I apologise that you may have been confused by both answers and I hope you now have the answer you need
Please PM me if you haven't...It will be treated in pure confidence
Chris
Now I'm confused. Chris didn't edit his original post (#1234), he quoted it and changed the wording to ensure there wasn't any further misunderstanding (#1243). From reading #1245 it seems that the whole subject has been clarified via PM, so lets hope this is the last we see/hear of it.
Indeed
Read back Colin
I've seen this before, with post editing after the effect for effect, I didn't like it back then either. Freedom members do get a longer grace period to edit posts along with other perks like hiding their own posts or topics. It can play havoc with the perception of whats going on or that the moderation team are hiding posts willy nilly, when in fact we're not.
Many will know I'm preparing a new site, with the new site comes a set of changes in how the software runs/handles 'stuff'. For the last week I've been making micro adjustments to permissions and settings. I made one this morning that will show the edited by/when for all, it was coming in the migration, it just got here a bit faster. I hope it clears things up a little.
Questioning likes? Come on, as of last week there are 468,863 likes, you want everyone justified or just a select few? hmm.
I'll never get why n+1 experts cannot agree to disagree, but it's been going on for a long time and will continue long after we've shuffled off to beading heaven.
"After all, those who will live in peace must agree to disagree in many things with their fellow-labourers, and not let little things part or disunite them." [wp]
As always, you hit the nail on the head with perspective. The changes are a necessary step I feel to prevent the above.
Now lets get back to those beading piccies before beading heaven beckons us all!!!
As requested Neil... Some lovely beadage.... :thumbup:
12193687_856440847802255_519082918462843
Very tight Ste! Lovely Jubbly!
Now that is lovely! :thumbup:
Very nice that - great capture too  B)
Sunshine this morning :) Although it's likely to be the last for a few days. Still, the rain should result in more beading opportunities...
BSD I presume Martin?
Edited by ChrisRs
Gonna sound dumb Chris, but being a noob to the world of detailing what's LSP and BSD? I presume there short for something
:whew: I was worried it was going to be way more complicated than that, cheers Chris
The simplest things in life are often the best
Edited by ChrisRs
