EML light on
Hi all EML light on is caused by cylinder 3 glow plug, what i want to know is if i replace glow plugs will EML eventually go off if fault solved ? thanks
paul
No, the eml will have to be cleared by an obd diagnostic device.
Or
Remove the battery for 15minutes...to reset the ECU after you've replaced the glow plug.
Hi, Do the glow plugs come out alright. Had a nightmare situation with a merc engine where The glow plug was carboned in so tight,it snapped off" ARGGGG"
