Dealer switches DRLs off - why?
Just looked again and there's a hole where its suppose it should be lol bugger lol
So possibly forgot to fit the drls on yours ?
DRLs are there, but after a certain build date (2014MY production start maybe) the option to turn them off is removed IIRC
Hi mines got a hole too, however the method with the indicator stalk works, it is fully explained in the manual.
Pete
Tried this method this morning with the stalk being pulled back turn the ignition wait for 4 flashes and a gong sound then they go off, only mine don't I rechecked to see if I did anything wrong as I had it written down but still nothing, just have to put up with it the car is a 2014 monte carlo first registered on the 31/1/2014 on a 63 plate, the only other option was to pull the fuse but my DRL fuse also shares something called stop/start radio.......now our car doesn't have a stop/start option, I'm assuming by stop/start this means the engine..??? but really don't know where the radio bit comes and to be honest with u I'm a bit on the wary side as the car is only 2 n half weeks old......
Pete
Right I've just read MY owners manual and it stated that to switch off DRL's if u have stop/start function to pull the stalk towards u and down and hold then turn on the ignition and wait for 4 flashes then turn off and wait for a audible gong sound then it go's on to tell u that ur DRL's are deactivated but my car doesn't have this stop/start system...........so above this section in the manual it states if u don't have the stop/start system then to take out the fuse......which is number 35 on my car so will try this tomorrow if it's dry......
OK pulled the fuse on my DRL's today as stated in my manual......all's well no more DRL's.....I'm a happy bunny now and can get on and enjoy the car..... :happy:
Hmm my vRS just had some warranty work done too and I noticed the Dealer did the same for mine. Didn't realise until it was dark and started my car, Normally you can see everything light up from the brightness of the LEDS :)
Ha, this thread makes me laugh at my own embarrasment. When I collected my new Superb estate last year I was so keen to get to grips with all the new gizmos I failed to turn off the DRLs, only to find after a hour the car would not start! Sheepessly I called up the garage for help. They were very understanding and sent a chap around to boost the battery. I bet he thought me a bit of a twit really.
Do you mean you left the ignition on and the DRL's on, but no engine running and run the battery down,
or do you have DRL's that work without Ignition on or the Engine running?
george
Sixty7 - two things -
1) Stop/start - I'm jealous.
2) you can't see the DRLs, so why do they bother you?
I got mine serviced yesterday, I haven't checked, but I'm sure the garage door was lit when I turned off my headlights...
1. my car don't have the stop/start set up........so no need to be jealous anymore....;)
2.it stops the lenses from misting up.......and I don't look like a boy racer with his fog lights on
I wouldn't worry about that -most folk see a Fabia with its fogs/DRLs on and think "old age/dementia" rather than boy/ racer lol ;-)
Then I'll look normal....:)
Then I'll look normal.... :)
Me too!
