Removing inner rear drivers side door panel
Hi all. I have read about the door latches failing and it seems that mine has also done this, on a 2007 56 plate Octavia mk2. The rear drivers side door would t lock with the central locking fob or the switch inside. I therefore think I need to get the door latch module out of the door to inspect and either replace or clean the micro switches. What I need to know is do I need to remove the window and all the other components to get at the door latch module. It seems that the panel which has the window winder motor attached and is sealed into the door is also riveted in. How do I remove this to get at the last h module? Cheers in advance for any help!
Drill out the rivets.
By some more of the plastic fasteners which hold on the door card, they are made of the most brittle plastic known to man.
Cheers for the reply, I did actually see this on another post, although was hoping there was a better way. If I can't get hold of a riveter can I just get some self tapping screws to put the panel back on? Cheers. Ade
£16 for a riveter from Screwfix. I suspect there won't be enough metal to get a self tapper to grip onto.
I'll have a look at that then, cheers. Ade
