Transferring the key fob internals into a new shell
Has anybody had the key fob open? How difficult would it be to transfer the internals into a new shell?
My keys are worn out and very scruffy, so wouldn't mind paying £2.70 to freshen them up with these.
it's pretty easy, the main PITA is transferring the immo chip. Nail varnish remover usually works to dissolve the glue though.
Hmm. Is it glued in good n proper or just a couple dabs? It looks pretty fragile
it's VERY fragile. Leave the nail varnish remover for a while to work. If the glass bead breaks, it's new immo time (read expensive)
I'm gonna have a crack at it. I'm not ham fisted, so hopefully it should go ok.
Famous last words
I've removed a few of them, also smashed one while trying to remove it!
They are made of glass I think.
Alternative is a silicone gel cover off eBay. Or just swap the rear end - as that's the bit with the buttons. Then maybe a polish up.
I did one for a bloke in work. He was convinced it wouldn't work, low and behold it worked fine.
****ing **** never paid me for the new shells I ordered for him either!
Famous last words
How'd you get on?
Not done it yet mate, I've ordered the shell but it hasn't turned up yet. Turbo blew up the other day so it's not high in priority at the moment
they're not that expensive. Transponder costs about £5 & as an example of how much programming costs I charge £30 locally within 10 mile radius of my home. I travel all over the country doing keys & usually wait till I have a few jobs in the same area so each person can pay an equal share of my travelling costs so it still doesn't work out expensive
How would you as a professional go about removing the transponder that's glued in?
nail varnish remover or a mild solvent. No fancy equipment or technique for that part of the job :)
Hi, I was going by dealer prices alone rather than the GB prices :)
Well the usual main problem if you break the transponder in your only key is that if you decide to get the dealers to do it you have to get it transported there.
much easier & cheaper to get somebody out because the dealers won't just supply a transponder. They'll try to sell you a full key
I swapped mine over 2 weeks ago - the most difficult part was trying to get the spring back in...
How did you get the skoda badge off to get at the screw? thing is welded in!
small flat bladed screwdriver, 3mm ish
Thats what I'm using. Also tried a knife but I was gonna end up with a hole in my hand. It's stuck solid
Stanly knife then. I take it the replacement fob came with a new foil badge?
Foil?! This thing is solid titanium stuck down with glue made by aliens!
But nah it didn't lol, I'm gonna order some vRS style badges to replace them
Job done for now anyway. Turns out my key didn't even have a transponder in it...
Either someone's wrong about that or something awkward has been done to the imobiliser.... Like it's disabled or some idiot has glued a transponder into the steering column.
that seems a bit odd to me. If it's an original Skoda key that still had the original Skoda logo fitted then there must be a transponder inside it.
If there isn't a transponder inside it then as vindaloo says it must be either taped up near the transponder coil around the barrel or it's had an immo delete done.
I'm going to be up in Newcastle at some point next month so if you want me to take a look at it while i'm in the area give me a shout
Check the sticker under the boot carpet, look for the code 7AH, if it's not there, you don't have an immobilizer.
You may have the code 7AF (Anti-theft alarm system and passenger compartment control) but no immo.
