engine turns off on idle
Hi,
I have a problem with engine. Every time I come to halt on traffic lights and put car on idle engine turns off.
The problem started like this: first i replaced water pump, belt, belt tensioner, thermostat, and intake pressure sensor and coolant.
After doing that car started to misfire and I took it to a mechanic who moved a little bit ignition distributor. With him doing that the misfireing of car stoped but now engine turns off on idle.
Any sugesstions please?
The car is Skoda Felicia 1,6 LX, 1997.
isn't it obvious you disturbed something in the process?
like you broke that MAP sensor without seeing...
it is either you messed something else and didn't see or the new parts are not compatible.
one thing is for sure: changing the timing by rotating the distributor is not a fix.
it is a botch.
