Handbrake "failure"
Older gen cars (like my 1P Leon) would start without having the clutch depressed. So a lot of people are used to something else.
  • Replies 251
  • Views 45.4k
  • Surely something soft between the two cars would have avoided any damage?
  • Had a voicemail from Skoda customer services, a new bumper should be at the body shop next week
  • Happened on an A3 at work. Did damage to 2 other cars and a wall. I always put cars I drive in gear, but that's how I was taught.
My handbrake hasn't failed. Just FYI.
FYI - From my quote above about my missus turning into the Hulk, she has an older Focus which does not require the clutch to be pressed for starting. I'm greatful my Octavia does have this feature
Edited by Rob123
It appears my horn was also damaged in the bump, it sounds like noddy's car now! :D
Seriously though does anyone know exactly where the horn is?
Cheers, just been looking on Etka myself, well the impact on mine was next to the numberplate on the drivers side which is the low tone horn so I assume that's buggered as i'm only getting the high tone.  Well there's nothing that can be done until the body shop get a new bumper and take mine off and have a look I guess.....
Spoke with SUK customer services again today, the guy has spoken to my Skoda dealers on the inspection they did on Friday and as they found nothing wrong there's not really more they can do.  I did mention the two other owners on here that have had the handbrake fail but understandably there's nothing SUK can do with just somone's word off the internet........  I don't know if other people plan on contacting SUK with regards their issues but I guess for now there's nothing more can be done until people do.
He's still also chasing up a new front bumper and will be contacting me again by Thursday....
I emailed Skoda UK over the weekend and also spoke to them earlier today. I explained the problem again and was told they had spoken to their technical people who cannot understand how this can happen and this is the first handbrake problem they had heard of!!!
As this problem has not reoccurred there is not much they can do so all I can do is report it again if / when it happens again.
I mentioned about the other two people on the forum who had handbrake issues and was told if owners do not report problems to Skoda UK they cannot sort them out or build up any history of problems.
Have you tried the 'MOT test' I posted earlier in this thread. With the handbrake on, push/hit the handle to the left and then to the right. If it releases, it is an MOT failure. i.e. you are pushing the ratchet pawl off the side of the ratchet plate.
The most common reason for this type of failure is owners climbing over the handbrake lever and bending the mechanism from the vertical.
I've also seen cases, where for one reason or another, the driver pulls up the handbrake lever with their right hand (or both) and is pulling the lever to the right as well as up.
I've not seen any faulty from the factory.
Good luck with the from bumper Neily03, it took seven weeks to get mine.
I've not seen it myself but swmbo complained the other day that the car started rolling at a set of lights.
I just put it down to hill hold coming off and jerking the car combined with her not pulling the handbrake up enough.
Will have to keep an eye on it. Worrying...
Interesting, i've spoken with them twice on this since Wednesday.  Do you fancy exchanging Reg's via PM for any future contact with SUK?  I'll be speaking to them later his week.
Yes I've tried that with no issues.
SWMBO complained of something similar with her vRS a week ago. I tested it by trying to pull away with the handbrake still up and it did so all to easily.
I exercised the handbrake about a dozen times - pulled it up quite high and released etc - and the handbrake appears to be better. SWMBO hasn't complained about it since.
Could be something to with the handbrake auto adjuster perhaps.
Had a voicemail from Skoda customer services, a new bumper should be at the body shop next week :)
Well my collegues car is all fixed now and he's happy so that's one less thing to the think about.  Just need to get mine sorted now.  :)
So hopefully by the end of April all should be done and dusted.
Fingers crossed :)
Hi neily03, how long did it take to get your new bumper? My car has been in for repair two weeks now after the wing mirror damage (earlier thread). The body shop phoned today saying they were still waiting for a bumper to be delivered.
Bumper is expected any day now and the car is going in on Monday, that'll make it 4 weeks. Think it's been help by me raising it with SUK.
OK, sorry guys, just thought I'd mention it just in case :) Is the Octavia the only one in the VAG family with a regular handbrake then?
People don't check their car is in neutral before starting?
Mine comes up with a message on maxidot if you try to start car when in gear.
Out of curiosity I tried it.
Mine doesn't, it only asks for the clutch pedal to be depressed other than that it can be in neutral or in gear.
