Changing to facelift model
Yes have some but right now I heve issue with Tapatalk that exceeded limit for free posting of pictures :angry:
Can I fix this somehow ?
(and avoid buying PRO version...)
:rolleyes:
photobucket?
Can I use photobucket on Android phone? Or isea how to use it on phone... sorry for stupid question:ph34r:
Not really. I'd do it like JaVa^ has done:
B40916D9-317C-495E-8654-70A1FB9564FD_zps
So what is needed to achieve this look. just a face lifted bumper and grill? Any Trimming involved
I'm always on the look out for FL parts, can anyone confirm that th emounting points are the same?
And will the FL headlights take the non FL headlight mounts?
Rob
Bumper must be modified below the headlights because the FL headlights are different shape than the Pre-FL lights. That requires some plastic welding. Also you need the bumper grills, DRL's, Fog Lights, plastic brackets to hold the DRL's and foglights, headlight washers. Basically you can't use any of the Pre-FL bumper parts. Also if you want to get the DRL's work like in FL you need to get a newer CECM and do some wiring.
  • 2 years later...
Sorry to bring up an old thread..don't even know whether you're still active but I've been looking at doing this recently, just wondered what you mean by a VECM with regards to wiring up the DRL's from the facelift bumper going onto a pre facelift car.
Central Electronics Control Module from FL RS is required for enabling the DLR's in factory style. You can also use fog light wiring (+resistors) and code them with VCDS to be used as DRL's. The problem is then that you have to build the foglight wiring and relaying from scratch as i did (not very OEM style to do it, but worked for me).
  • 6 years later...
Did you have to change the slam panel to facelift?
