low level sensor of windshield washerfluid tank
Hello Everybody,
Today morning out the windscreen washer fluid in my car.
I didn't notice any warning light at all, which signaling me the low level of washer fluid.
Is it possible,  my car doesn't contain this sensor?
How can I be sure, it really doesn't contain it? I
The other possible thing is went to wrong if it is available in my car.
Thanks in advance.
The sensor Connection wiring may be loose or has become detached. Sensor should be present. Light on dash may be faulty also. If under warranty should be covered by dealer.
Don't know if Superb is the same as most Skoda cars, as in that you only get windscreen fluid level warning when headlight washers are fitted.
Thank you of your responses.
My car is 2010.11 the warranty period is expired. :-(
I not found any option code at all which related of sensor of low level washer fluid.
My car doesn't contains headlight washer. it's a base equipped model.
I've got a 2012 greenline se and I have no headlight washers. I do have a warning light for my fluid though.
I've had 1 Octavia and 2 Superbs, manufactured from 2001 - 2010.
None had headlamp washers, all 3 have / had washer fluid level warnings.
