Breaking Mk1 Fabia vRS - READ POST #1 FIRST!
As people were still asking for parts not the list below in my other thread, this the definitive list of available parts.
Collection from near Gloucester or happy to courier most of the parts.
Open to offers.
Exterior
under chassis guards
exhaust mounts
Engine bay
servo
front wiper mechanism
scuttle panel
air con pipes
engine wiring loom
fuel filter holder
ECU
Interior
front and rear seatbelts
door/boot/bonnet seals
indicator stalks
clutch/brake/accelerator pedals
sun visors
perforated handbrake lever
interior wiring loom
heater units
steering column
flip key
boot lid interior trim
front windows
A pillar trims
upper dashboard
  • Replies 106
  • Views 10.8k
do you have steering wheel and airbag
Hi, interested in the drivers door window switch and rear part of it too so both bits...price posted please?? Not sure where you are...
Passenger front half top armrest that has the window switch in. Don't need the switch just the plastic surround.
Also the washer jets if they are available?
Gearknob and gaiter available?
If the part you want isn't in the list, then I don't have it..
Don't worry then.
Original list updated
Any info on he arb? Standard part?
Also front cup holder available? Also how much posted to Kent?
Edited by joshcowin
Standard ARB
No cup holders available
I'm after the air con pipe from the front drivers side lower then runs up the drivers side chassis leg is poss?
Thanks dan
Thanks dan
Hi Dan
Is that the one from the compressor that then runs up the drivers side chassis leg?
Hi Jambro,  what colour is the bootlid & spoiler?  Ta
It's Diamond Silver
Ah ha cool!  Is the spoiler in good condition & no lacquer peel?  Need to replace / repaint mine.  Don't suppose you'd split the boot & spoiler?
How much for starting motor posted please
left hand boot trim? Connects the carpet to the lower trim? Any pictures? Thanks :)
No lacquer peel, just needs a polish to bring out some light scratches.
Tailgate and spoiler are going together as they're a pita to separate. You welcome to buy the lot and have a go yourself! Offer still stands on the RARB and I'll even meet you just off the southern M5 junction of Gloucester!
£30 delivered
Gone already
Hi Dan
I'll double check but think so, does a 180 degree bend before entering the air con rad? Thanks
Pictures on my ebay ad: 221408368272
The one you're after could be the one that's slightly bent
Its the one in the second picture I believe, how much would that be if its all okay? Thanks dan
How much for the Carpet?
thanks
If the Scuttle panel is standard - How much and where are you?
Chip
It's that one that's been bent out of shape, so I'm guessing no good to you? I had just included it as a freebie with the other one! You can have it for the cost of courier if you want it? £15..
thanks
£20
Hi jambro, is the resistor pack avaliable?
as per http://www.briskoda.net/forums/topic/178661-fan-only-works-on-higher-speeds/
Hi, sorry not available
Chip
I haven't got the plastic scuttle panel below the windscreen, but I have got the metal panel than fixes to the bulkhead
Depends which bit you need? I'm near Gloucester
Guest
