LED fog light bulb coding / adaptation now found
I was having a look through the loooooooong list of adaptations and I have worked out the channels to change if you decided to upgrade your fog light bulbs to LED ones like I have. Tried and tested on my 2014 vRS, but should work on non vRS by just doing the 2 channels.
Hopefully Andyvee can add these to the tweaks page.
Fog light LED coding
(1)-Leuchte12NL LB45-Lasttyp 12 (FOG left inner) from “10 - allgemeine Scheinwerfer” to  6 – LED Lichtmodul
(1)-Leuchte13NL RB5-Lasttyp 13 (FOG right inner) from “10 - allgemeine Scheinwerfer” to  6 – LED Lichtmodul
(1)-Leuchte8FL LB39-Lasttyp 8 (FOG left outer) from “10 - allgemeine Scheinwerfer” to  6 – LED Lichtmodul
(1)-Leuchte9FL RB2-Lasttyp 9 (FOG right outer) from “10 - allgemeine Scheinwerfer” to  6 – LED Lichtmodul
All works perfectly, allgemeine Scheinwerfer = general spotlight
Result! Thanks for sharing
Added - thanks
  • 7 years later...
Hi @xpower I know this is an old thread and there's likely other topics that cover this, but out of interest, what led fogs did you install? Safe to say, the foglights on my scout are pony!
