Felicia Handling
After seeing Felicia16v's Feli at Castle Combe last month, I started looking into perhaps the possibility of getting a Felicia Project/Track Car as they are pretty cheap to pick up.
Just wondering how they handled as standard when your pushing them (im guessing they're not brilliant), and if there are any good mods to aid its handling?
Does the Felicia share anything from the Polo or other VAG cars from that era?
Cheers :)
hi, the felicia is basically a reworked favorit underneath, and there is no vag group parts fitted to it except for the steering wheel and the vw engines, it even has a skoda geabox.
that said they can be made to handle pretty well with a few tweaks, there are a few options out there for engine transplants and/or tuning etc but theres not many mainstreams bits out there, it will be cobbled together with bits from other vehicles. i love felicia's personally.
I've seen your 1.8T and other heard of other engine swaps like the 1.6 and 1.4 16V (AFH) engine swaps, is it a matter of just bolting it in using Polo or Golf engine mounts?
I see you 1.8T needs a bit of fabrication, but i wasnt sure if the VW engines simply dropped in and bolted onto the 5 spd gearbox
Am i right in saying that the same 5 spd was used thoughout the Feli?
the 1.4 16v afh engine is almost a straight bolt in fit using a lot of the oem parts from a 1.6 petrol felicia
here http://www.briskoda.net/forums/topic/107541-felicia-1-4-16v-engine-transplant/
you only need 1 custom made piece.
they all have the same gearbox transmission housing yes which natively belongs to the 1.3 ally block skoda pushrod engines, but on the vw engined cars (1.6 aee and 1.9 aef) there is a cast iron adaptor plate bolted bewteen the engine and gearbox, the only other differences are the gear ratios and final drive ratio are not all the same across the range but the gearboxes will interchange between engine types so long as you use the adaptor plate (as required)
I suppose if i were after any serious power, id be looking at the VR6 or 1.8T conversion route?
IIRC the 1.4 16V cant really be tweaked? or am i mistaken?
have a look at what the member called fruitbat on here has done, it's running on motorcycle throttle bodies and makes decent power. probably not very road friendly tbh but i bet it's a screamer.
1.8T and vr6 all possible, but it's going to cost you some serious dollar and it's fraught with major difficulties. i'd like to see a ford zetec engine fall into a felicia, in fact i might do that on my fun eventually
Funny you say that, a mate at work has been trying to persuade me to buy an old Ford and fit a Zetec in it as all their bell housings are the same etc.
Tom do you know which 1.6 16V engine will fit? as in engine code?
edit: Is it the AJV engine from the 6N Polo GTI?
avy engine code is the puppy you are after, from a 6n2 polo gti, 1.6 16v 125bhp on the standard fuel injection gear but it would need the ecu and wiring sorted to make it work right, also you would be better off swapping the large alloy sump to the pressed steel type too for clearance for the exhaust system
Does the 1.4 16V AFH have the Pressed steel sump? or does it have to come from elsewhere?
TBH Wiring & Electrics does not worry me at all as its part of my job (Electronics Apprentice)
Reading your 16V conversion thread it would appear to be better to start with the 1.6 Felicia instead of the 1.3.
Ok so engine wise its pretty clear id be going down the 16V route, but handling
Does the Feli have a front ARB? Doesnt seem like theres alot out there on the internet regarding suspension mods for the old feli.
yes the afh engine has the pressed steel sump fitted, it is identical to the one on the 1.6 aee engine too..
there's 2 schools of thought on which is the best base vehicle to start with, the 1.6 model will be a good donor for all the parts you need to complete it, however the 1.3 mpi has a much closer ratio gearbox with it's 4.11;1 final drive plus it sits in the lower tax band (upto 1459cc) which means less jiggery pokery with the dvla getting the tax band changed, you would only need to notify of a cc change, in reality it makes little difference which one base model you use but there are a few minor differences to the engine bay wiring loom which is easy enough to sort
some do some dont, the 1.6 and diesel models have them fitted, it's a 20mm bar, but it seems it's pot luck on the 1.3 models, but you can retro fit one nevertheless, also which is handy the fun and pickups have a 22mm bar which is a good cheap upgrade (£85 new from dealer) or a tenner from a breakers yard
suspension wise there is virtually nothing around except lowering springs in the uk, but with a bit of magical trickery you can fit the front coilovers from a mk1 ford focus on there, and use mk3 golf or mk4 polo ones on the back
I have also read that 1.3 models dont have PAS, so surely Id need to delete the PAS pump on either 16V engine? if of course i went with a 1300.
some have power steering, it depends on which spec model you go for, you can either retro fit the power steering ( theres a topic in the classic models guide section on that) or you can just whip the power steering pump off the engine and use a shorter belt, there is an oem belt available for this exact purpose
PAS sooo overrated! haha
So am i right in saying that the AVY 1.6 16V (fitted with the AFH Cylinder head) drops in with:
Small amount of Engine mount fabrication
Smaller Pressed steel sump from 1.6 8V AEE
bit of magic with the exhaust and the engine wiring.
ok, if you are going to use the afh cylinder head on a 1.6 block then you can just use the afh ecu with a modified 1.6 felicia fuel injection loom as a plug and play fit.. and it will fall straight in there like it was made for it, can be done inside a day if you are handy with the spanners
also the exhaust system from a diesel model is 2" inch system which is a useful upgrade over the standard 42mm system from the petrol models, the diesel system is a straight bolt on fit too but you would need to extend the front part where it joins the cat
Would you say it was worth fitting the AFH head or should i keep it on the standard AVY one?
Im trying to keep track of which mods you had fitted to your feli at different stages of your 16v Thread haha
ideally you would stick in the engine as a complete un-opened unit, but the avy engine is a bit more complicated because it has variable valve timing and the ecu is not compatible with the oem wiring loom in a felicia, and it is also drive by wire operated too, you could just get the entire loom and ecu and the pedal position sensor unit from the donor polo and modify to work in a felicia, but this adds another level of complexity to the build and is not for a complete novice to tackle.
Ok :) lol Ive just got to the point where you suggested fitting the AVY Crank, pistons and rods to the 1.4 AFH Block n Head. Possibly also fit the 120 Injectors from the 1.6?
I presume they are the same bore, just a different stroke?
eliminating the issues with the cylinder head bolts and is easier for the ECU wiring etc.
theres not much advantage in fitting the 120cc/min injectors, mine made 129.6bhp on jkm's heartbreak rollers running on the purple 100cc/min injectors
yes the bore size is the same on the 1.4 and 1.6 engines, the rod and piston combo must be fitted as a matched assembly because the different engine sizes have a different piston/rod length ratio and piston compression height, or in laymans terms the avy piston and rod must stay together, dont mix and match.
the only advantage the avy block has over the afh block is that is has under piston spray jets which squirt up oil rather than relying solely on the internally drilled rod to feed lubricating oil to the small ends of the connecting rods..
if you are going down that route you dont have to use avy components, there are a few other engine codes form a mk4 golf (atn, aus azd + a few others) you can get the pistons and rods from, it's prohibitively expensive to buy them new from vw. circa £120 each for the pistons, and circa £350 for a set of 4 connecting rods
so really id be looking at getting my hands on 2nd hand pistons, rods, (what about the crank?) and re-ringing and bearing them respectively?
it's starting to sound expensive isn't it? :bandit:
try a breakers yard for a scrap engine, yes get the crankshaft too, i would whip all the bearings too and just re-use them, especially if it's just a street rod you are going to thrash. or just the journals re-polished by a engine repair shop and re-use the bearings from the afh block. i know that sounds like a bodge but it stands you at less money in
To be honest Im looking right now at a VW Polo 2001 (6N2 or a Mk3 Facelift what ever they call it) with a 1.4 16V engine, which im guessing is the 100 BHP AFH engine.
I could pull that out and scrap the rest of the car to recoup some cash.
Then find a 1.6 16V engine, where as you said i could strip the old rods pistons and crank.
I dont think it sounds too expensive. alot cheaper than my other project ideas! :D How much is one of your fancy engine mounts for 16V conversion?
If it's a 6n2 it will be an aua or aub engine code, this WONT fit the skoda gearbox, it has a different bellhousing.
Hmmm I thought the 6N2 was just a facelift and still used the same engines as the previous model, unlike the Bug eyed Mk4 Polo which i know did have the AUA/AUB engines :S
