Rough idle after service.
These could be old codes
Just going to clear them and start car, go for a run and do another test.
Sent from my GT-I9505 using Tapatalk
It now says there aren't any fault codes...
Try again in a few days :)
Thought it would show straight away lol right impatient me. Will try again tomorrow evening because mechanics going to look at it monday evening and ideally I wanted to turn up with some codes and the cause.
Also on the readiness part of the device there's a few things that show as fail. Can only remember these 2 at top of my head. Is it relevant?
Catalyst
02 sensor
When you fitted your decat did you fit a fooler to the lamba?
It doesn't have a decat... just a normal cat was replaced at the same time though was an advisory on MOT as badly corroded.
Had the same problem with mine and replaced the maf, seemed to run better but still had eml light on and found a big split in one of the vac pipes under the inlet manifold. Changed the pipe at a cost of £18 and now it runs spot on. I ran the engine and could feel a slight blow on my hand when feeling around.
I had exactly the same problem, rough idle but car was running fine on the road. It proved to be the above hose. It is not always easy to find out as the cut was not visible. But I think I had different fault codes...and the catalyst temp was very high. This is what happened to me:
http://diy-vag-20vt.blogspot.gr/2014/02/diy-breather-hose-06a-103-221.html
Yeah I had lambda sensor fault, random misfire and misfire bank 1 and 2 show up as faults and a slight flat spot a 3000rpm (really slight though). All happened just after I decatted it so thought it was to do with that but turned out to be this. Could be worth getting a good look at that pipe just in case, its a real bugger to get too though.
Right... ive been out and had a good look round all the pipes I can reach and there all fine buttt my dip stick is snapped!! And it's snapped off right at the bottom. Will this be the cause? Can't believe it's snapped!!
Is it still ok to drive till a replacement turns up?
Just safely bung up the tube that remains
Okay dokay I'm guess this isn't causing the misfire? Just adding to the list? Lol
Just to let everyone know I had a bent spark plug so mechanic replaced with new ones and now its sorted and flies again.
Thanks everyone :).
