2003 MK1 Fabia VRS Breaking - What's left is off to the tip so if you wanted it, you're too late
Still got rear seats?
 PM'd
Do you have that little pully thing that's got  " ON " written on it please.?
:notme:
:notme:
Yes I do, but you'll have to buy the dash board if you want it :D
Hi mate do u still have the gearbox and how much you want fort it thanks
Sent from my GT-I9300 using Tapatalk
You may have seen my other thread regarding breaking my MK1 Fabia vrs. I've sold lots of stuff now so I thought I'd start a new thread with a comprehensive list of what I have left. If it's not on this list, I do not have it.
I'll give you a clue...
it's not on the list.
Hi Haydn
is the gear stick and gaiter still avail per chance
colin
Edited by Steamfan
Hi Haydn
colin
It IS on the list, so I would say there is a bloody good chance its available, else it wouldn't be on the list. ;)
Hi Haydn
colin
It is indeed. Slight laquer peel at the very top but at £9 posted it's a proper bargain. Pm me if you want it. Cheers.
Someone could well have contacted the vendor previously in this regard. That is why I asked if it was still available. Moreover, your response is not welcome being blunt and downright rude !
Furthermore, as you are not the vendor I fail to understand why you see fit to stick your oar in. Whats more I am sure Haydn is a big lad and can look after his own affairs.
I don't think Jason was trying to be rude, he's merely picked up that people keep asking for things not on the list when there is a nice sentence at the top of the first post saying if it's not on the list, I don't have it. It's good to have a query about something on the list :D
Still here if you want it.
What colour is the dash matey and is it complete?
First post updated, remember, if it's not on the list, it's gone.
PM sent re. boot floor mat
Edited by mark-o-polo
Are the cv joints and boots good on the NS driveshaft?
Need the space in the garage next weekend so if you want anything from my list, be quick because whatever doesn't sell will be going to the tip.
Last resort, I would do a simple photo of a pile, 99p start, buyer collects.  Job done.  Some tasty bits left.  I have selected some items which I think should never go to the tip.
Personally if you find you have the two engine mounts left, I will liberate them off you with some beers when I come in August ;)  Think I will need spares eventually especially as I had to have O/S mount helicoiled on one of the three bolts going down into that ally block bit on the side of the engine.
L/H Rear light cluster-              £8 collected - £15 posted
(with bulbs)
Dashboard (without airbag) -    £5 collected - £25 posted
Dashboard (with airbag) -         £10 collected
Front subframe -                       £5 collected - £20 posted
Gear stick mech and linkages- £10 collected - £20 posted
Engine bay seal -                      £5 collected - £10 posted
Front crash bar -                       £5 collected - £15 posted
Rear crash bar -                       £5 collected -£15 posted
Front ARB with mounts and
Drop links -                               £5 collected £18 posted (non VRS UPGRADE!)
Boost pipes -                            £5 each collected - £8 each posted
- Plastic hard pipe
- Hard pipe to EGR valve 90 degree
- Lower metal hard pipe
Horns -                                    £5 collected - £8 posted
Bosch S3 Battery with receipt -   £20 collected
(Originally purchased 1/12/12)
Coolant expansion bottle -   £5 collected - £8 posted
Drivers seat belt -                 £5 collected - £12 posted
Rear belts and buckles -      £10 collected - £18 posted
(Full set)
Front wiper motor + mech -  £5 collected - £15 posted
Boot side carpets -               £5 ea collected - £10 ea posted
Heater motor -                     £10 collected - £18 posted
A pillar trims -                      £3 ea collected - £8 ea posted
(Middle clip mounts broke)
N/S internal trim plastic -   £5 collected - £16 posted
(Full set)
O/S internal trim plastics - £5 collected - £16 posted
(Full set minus bit by driver's foot)
Boot + hatch plastics -       £10 collected - £20 posted
(Full set minus 1 bit in back left corner
Door carriers -                   £5 ea collected - £15 ea posted
(Speaker damage on N/S front)
O/S inner wing Engine mount -  £10 collected n- £18 posted
N/S engine mount -          £10 collected - £18 posted
Power steering pump -    £20 collected - £30 posted
Front mud flaps -             £5 collected - £8 posted
Steel spare 16" with -       £20 collected - £35 posted
very good Michelin primacy tyre
Indicator stalks -             £5 collected - £10 posted
ECU with custom code -  £50 collected - £55 posted
stage 1 remap
Covinience ecu -            £5 collected - £10 posted
Headlight switch -          £4 collected - £7 posted
Heater controls -            £5 collected - £10 posted
Interior mirror -             £5 collected - £8 posted
Brake light switch -       £3 collected - £5 posted
Clutch pedal switch -    £3 collected - £5 posted
ABS pump -                 £20 collected - £30 posted
O/S drive shaft -          £5 collected - £20 posted
(outer cv thread damaged)
Power steering rack -   £10 collected - £25 posted
Fuel tank -                 £10 collected
Scuttle panel -            £5 collected - £15 posted
Front wiper arms - £8 pair collected - £15 posted
Clutch foot rest -         £3 collected - £6 posted
288mm calipers and carriers -   £15 ea collected - £25 ea posted
Rear seats -                £20 collected - £35 posted
(One slight pull in fabric)
Full set of vw polo seats -  £100 Collected
(Grey cloth with striped pattern)
Dark grey/black carpet -    £10 collected
(Tiny bit of wear by foot rest)
Dark grey/black roof lining -  £10 collected
Ream beam -             £10 collected
(No brakes on it)
Throttle pedal -           £10 collected - £15 posted
Genuine VRS Floor mats -   £30 collected - £38 delivered
(Full set VGC apart from one
very very small tear on edge
of drivers mat)
Bump :D
What does the N/S front door carrier still have attached to it? My window is buggered!!
pm'd
Last chance for parts, it's all being cleared out later today. Please read list on first post and if there's anything you want, ask quickly to avoid bitter disappointment.
Locking this now as I've now cleared the garage out and the last few unwanted bits are in a pile in the back yard getting rained on while they wait to go to the tip. Many thanks to all those who bought stuff :thumbup:
Guest
