Boot dimensions
Could someone please measure there boot dimensions on the estate.
Looking for width, depth and height. Trying to compare to my current car.
Is this for a item you need to fit as last week on here someone was told by a dealer that their dog cage would fit only to find on collecting said new car it did not!
Take your golf trolly or suite cases etc to a dealer and try them out is the best way imho.
No, were looking at buggys for the new arrival with space left over for dogs etc so were just seeing what room there would be.  Were are working with measuring tapes etc at the moment as we dont have anything yet.
Looks like you will need a elastic boot space as I found out with a growing family you can never have a big enough car !!!
The boot will contain kit for 4 adults plus walking gear for 2 weeks away on holiday so should do you OK.
101cm wide, 106cm deep to the bottom of the back of the seats, they do have a slight lean, so narrower at the top and 61cm from base to pull over cover.
Edited by Crogers
Lol, I'm aware that's going to happen ;)
Thanks for that. Not massively bigger than the BMW other than height TBH.
On the width is that between the rear wheel arches? Also would it be possible to roughly guess depth at the top of the seats to rear screen as this is where my car seems to be quite bad.
Edited by coullstar
Yep this between the wheel arches, there is probably a 5-10 difference at the top, if you want a massive boot the superb seems bigger
Cool, thats spot on.  Just physically compared them and its plenty of big enough I reckon.
I have just checked and I think the difference is 15-20 between top and bottom, it's a very big boot, a lot bigger than the mk2
