strange sound
Hi i currently have a problem on my felicia, when im driving between 25-30 kmph i hear a strange sound like woo woo woo, when i reach 40km+ it goes away what could it be ?
Wheel bearing gone?
I agree with Teflon Tom - wheel bearing. Does it get worse or better through corners? The weight shift when cornering usually alters the noise characteristic.
I have a bearing issue but its a humming sound not woo woo sound the sound comes when the car is hot or after a good run when at slow speed 30kmph or less
unless you forgot to torque some wheel studs, it's rim/tyre related.
maybe a cv joint.
The primary bearing shaft in the gearbox?
(my english  :sick: )
Edited by pincopallino3401
The sound is only when hot after a good run any ideas ?
The sound is like when a big truck brakes i donno if you sometime heard it
@jonnycilia
other than asking for our opinion, what have you done to try to determine the source of the noise?
also you fail giving us details on prior related repairs and that is not helping you.
for somebody concerned about a car issue we pull out information from you with a plier...
the less information you share, the worse replies you get.
so far it can be anything from brake pads and wobbling brake disc to a noisy cv joint.
thanks for your replies, guess wat was it ? the disk brake was loose and tthe wheel nuts were tightened too mucch in fact when i tried tto remove the wheel the spacer expoded lol. but now everythings back to normal :)
