This weekends adventure has been fitting Coilovers. it took all day and a lot of hard work... i.e. getting the old struts out, but we got there in the end.
well worth doing, the back is sitting well; but the front needs to go a bit lower. i don't have the C spanners to lower the front as i didn't buy these new, so i can adjust the front just yet.
but I'm happy with it, it handles better and sits a lot nicer. the ride is a lot more firm but thats just they price you have to pay really.
Coilovers-
10470217_10203446533276902_4359426927212
Coilovers in-
10570326_10203446532916893_1087673932117
Wheel on-
10533994_10203446533596910_2915568312592
Sitting low-
10485841_10203446532436881_3035574733389
10568974_10203446531356854_2004387919164
Looks good, did you do this on your drive on a trolley jack?
Sent from my SM-N9005 using Tapatalk
Looks good lowered. Might be worth considering some spacers as the rear wheels now look a little too 'tucked in' under the arches tho :-)
i did it on my drive yes but i had the car on axel stands. The jack was there just incase the axel stands failed.. better to be safe then sorry
yeah i know what you mean mate, i think i will get them at some point
Car looks well Jay, nice and shiny
Before you lower the front more, I'd suggest try raising the rear a shade and adding spacers.
Slammed Fabia with tucked wheels looks weird.
Low(er) ride height and filled arches will look way beefier, and oddly more squat because of the wide stance than just slamming it.
What make are the CO's?
thanks mate! And i will higher the rear i just need to get som C spanners to be able to do it. I will deffinetly get some spacers and bring the back out a bit further.
And they are FK coilovers mate
Your insurers must be rubbing their hands together   :)
DPM Performance have good prices on FK hubcentric spacers and they include extended bolts.
I ran 15mm front and 17mm rear and they were pretty much flush on my Fabia, think they would sit really nice on yours. The car looks so much wider when you do this.
Keep plugging on with the car, I think it will be something quite special when/if you get done modding it.
DPM Performance have good prices on FK hubcentric spacers and they include extended bolts.I ran 15mm front and 17mm rear and they were pretty much flush on my Fabia, think they would sit really nice on yours. The car looks so much wider when you do this.Keep plugging on with the car, I think it will be something quite special when/if you get done modding it.
okay mate thanks ill have a look into that!
And yeah it should be pretty good when im done with it, got a few more things to go yet!
-remap (revo stage one)
-forge induction + the forge valve
spacers
then going to upgrade the sound system, maybe do a little boot build or something.
+1 to above, probably a little more practical too on our *smooth* roads.
I was going to put spacers on as sparkly said in previous post but can't afford to lower just now so holding off, waiting for a price on springs from Skoda that will keep the warranty. Will your CO's void the warranty?
The car is going to look very tidy when you are done. Great work Jay, enjoying following your project, keep the updates coming.
yeah i know, money is my issue -.-
and cheers mate, it should be pretty good when its done, ill keep posting updates
Jay cars looking sweet! I've got the same monte and I'm about to put mine on coilovers and space the wheels, affraid of the wheels rubbing though, are yours? I've got spiders to go on mine but still 17'
ive just lowerd it further, i think its sitting at about 70mm drop now. And ive had no rubbing or anything so you should be fine. You can always adjust them anyway mate! Your 17's should be fine
And cheers, its finally getting to where i want it to be. Ive got a few more plans i just need the money lol.
have you got pictures of the new drop?
here you got mate-
Only problem with dropping a monte is that the black trim makes it look like space between the arch and the tyre so it looks like it's higher than it is! Hopefully the spiders will look decent on it too! Space it maybe 15 or 20mm
That's sitting nice and low now!
