Phil's Octavia vRS estate build thread
I paid £1500 delivered for a low milage (28k) enging with turbo, injectors etc still on it.
Whats happened to yours?
  • Replies 223
  • Views 36k
  • I've not posted much about the BBS LMs. I have fully stripped them down, polished the dish and painted the centres in original BBS gold. Fitted new red/gold genuin BBS crntre caps. Also fitted genuin
  • Cheers mate. Few updated shots of the car..
That doesn't seem too bad.. Where did you get yours from, and any tips on sourcing a legit engine?
Had almost identical issue to your 5 weeks ago- diesel leak from fuel filter perishes fan belt which disintegrates into cambelt which skips 5 teeth. 12 new valves and 16 rocker arms replaced. Garage reckon it would have cost £3k but they cover costs due to diesel leak. I only had to pay £400 for new cambelt and a seized glow plug.
I breathe big sigh of relief.
3 weeks later lose power then engine stalls. Garage are saying there is swarf in fuel system and most likely cause is failed high pressure fuel pump (yet to be confirmed), and if so it's unrelated to all the engine work done just 3 weeks ago. I've obviously got a different view of the cause! We'll cross that bridge later..
Likely to need whole new fuel system including fuel pump and injectors, all they've said is that repair costs may be "prohibitive".
Edited by davew255
I have a spare fuel pump and injectors, they will be for sale in the new year.
I actually have a fair bit of oil/diesel around the boost pipe near the AUX belt, so i'll check that out as that may be why the belt failed. I presumed that was just a leaky intercooler pipe and the crap that comes out of them.
The engine was just from ebay, i had been watching a few different ones, but in the end went for the one that had the turbo and injectors etc still on it. That way i've got spare turbo, pump, injectors and what ever else i can salvage from my broken engine.
Might be interested in those. Let me know when up for sale. Will you be selling the pump and injectors from your old engine? What mileage?
Mine leaked diesel from under the fuel filter cap by the o-ring. Fairly common apparently.
I don't know what the plan is for using what yet, but i will probably get them all stripped and overhauled whilst there out of the engine.
I'm just in the process of sorting out a GTB2260VK turbo, so might need a bigger fuel pump anyway ;)
Few christmas presents for myaelf today.
Quaife LSD.
ARP fitting kit.
Sachs organic clutch.
Sachs SMF.
Sachs bearings.
EGR delete and cooler delete.
6FEB5790-77C7-4D79-B9C1-C553688C0880_zps
Quaife LSD.
ARP fitting kit.
Sachs SMF.
Sachs bearings.
A718A495-1767-4852-94A5-9A251062E07E_zps
Ouch alot of work for the DMF and clutch
Sent from my Galaxy S5
Lots more space though
The engines knackered mate...
Read above the latest post ;)
Err what have we missed?
Look at top of page
Look at top of page
Previous page. Must have missed that bit
Yer engine is knackered.
So had a bit of fun yesterday sorting out the new engine. Swapped over altinator, aircon and electric water pump. Removed the whole EGR system. Adapted the coolant hoses as the thermostat body is different from my car to the newer CEGA engine. Also swapped looms as the loom that came with the new engine had a cut in it for the electric water pump.
Fitted new timing belt kit and waterpump and new AUX belt.
Swapped over the intakes as the new CEGA engine is all plastic, i liked the metal intake better. Fitted SMF and clutch so engine is basically ready to be refitted.
Friday the gearbox will be split and LSD fitted.
36001F4D-82DE-451B-A160-9ADBA342531C_zps
F248206F-F3A7-4B0C-AAF8-9576AFF1FF0F_zps
CDDA4234-BCE2-4322-9618-F01D1D25AC35_zps
7CB0F9CA-F166-4555-861B-40D62CA85BBE_zps
551F4FC8-CA4D-4EF0-B663-722ED44B96FA_zps
4A33C7BC-F74E-459A-9338-A060E3BFA948_zps
A9B494FC-3A5B-4E88-ACE3-594609A20D6F_zps
Few better pics of under the rocker cover, cant wait to get the head off.
7A06498B-5AA4-4785-AF8F-597BD5329E6B_zps
Got myself a 5th wheel too, will spray this at weekend.
27D20F06-ED59-43D0-B84D-1D29180B2A4F_zps
Coming together then lol I see you still have the porsche rims. I take it your keeping them lol
Yer i like them too much really.
I don't have a spare that fits over my brakes so another one was the easy option.
Cool at least you are not doing it on your drive lol
Bit of an update. Got the bearings out the gearbox and nee ones on the diff, also diff bolted in. Just needs putting back together now.
539D52C8-23B1-417D-A709-971DE4DB41D7_zps
9C3A75F1-9AD0-4792-B595-0E2C535C8361_zps
F42D0C7E-0205-4BD0-892C-8CC8D0B17171_zps
5C7F3870-110A-44DC-A455-1E83B8A3733A_zps
6C85E115-5EE6-41DE-ABB9-0EBC0F10AC04_zps
FA74052D-73E1-4994-849D-AA8E2A601AAF_zps
DF7D6326-82C2-4284-9B2C-E66475093829_zps
BDFE05C0-5274-46FE-8474-C8300D245DB1_zps
CEB43455-95BF-45F4-880D-30F87872815B_zps
More to come :-)
More to come :-)
What a fantastic project. Good work
