Sheered stud when changing downpipe - HELP PLEASE!
Ok, this is currently being discussed in another thread but need more eyes having a look and options of any, so have created its own thread.
Mankee has already suggested trying to get a bolt on the remaining bit of stud to try and wind it out. my answer below which also explains my problem:
Basically out the four bolts 2 came off with not too much trouble, the other two decided to be tits. We cracked them and they started un doing, went tight and then really tight. One sheered and the other actually undid the stud from the manifold (I think that's what it is called!?) we managed to get the stud back in as we just used the nut on it to tighten it back in and then fortunately it stayed strong whilst we tightened the nut up further.
There is enough of the stud showing to be able to get mole grips on it, however when we tried this the grips just started to chew the thread! I'm not sure a nut will go on it to be honest. Anything else I could try?? I will try the nut solution but as it sheered I think it would just sheer again?
Edited by frenchieg
I'd drill it out if possible and retap it. Or maybe try a stud removal tool.
This ^^^ I've used the Workzone (Aldi) kit and it shocked me and is really good
I would have no idea how I would get a drill in there. Could barely get the wrench in to get the damn things off. Unless you know something I don't? Also to re-tap it would be very difficult as again not a lot of space
i had to remove the turbo and weld a nut to the stud when this happened to me :clap: came off easy on the bench with 1/2 breaker bar :p
You can get angled drills :)
When you say you used it, do you mean you sheered the stud and this is what you used to get it out? Any chance you could get a pic of what kit you're on about please? Thanks
can you apply some heat at all?
Crap this is not what I wanted as its my daily. Ooops. Is it relatively easy getting the turbo out, or would I be able to weld a nut on with it in place??
Aldi equivalent of this and then used a tap :)397991dde432e0710371e5a5061be864.jpg
I really don't think drilling and re-tapping it is an option, unless I take the turbo out which I'm really trying to avoid. But thanks
Sorry didn't realise it was a turbo as there was no mention of what exact model!
Did you do this with the turbo still on the car? I'm bewildered as to how you managed that if you did :no:
See my post above!
Ha no worries although it does say on my member info to the left that my car is 1.8t 20v :D  :D
On tapatalk so it didn't show up until I just looked whilst on website
Will be an option if I can get a torch but if I get one of those i'll just weld a nut on if I can like terkin suggested
I'm being thick, whats the difference between stud removal tool and drill n tap?? :drunk:
stud removal tool is what Toxic posted a pic of. It goes into the stud anti-clockwise (left hand thread) bites into the stud and unscrews it.
Ah ok, that maybe an option if I can't get someone with a torch a weld a nut. So just to clarify, the tool that toxic posted a pic of gets screwed on, assuming you need a fair bit of pressure? and eventually unscrews the stud after biting into it? Is this correct?
I really don't fancy taking the turbo out :'(
Did you try the tool that's been posted above Terkin the pic Toxic posted??
is abit of a misson the first time you try to remove one,on your own will take forever.
yea they are a non starter for this job just no room.
Ok so going to get a stud removal kit and try to heat it a little before I try get it out.
Does anybody know what size the studs are or a part number for them and the nuts please??
