Removing ignition coils
Quick update, the light came on again and I took it in to the dealer who did a software update. Drove to work the next day and the exhaust warning light came on and stayed on this time, took it back in to the dealer and they cleared the fault and booked it in to have a proper look as the fault code said it was running rich. Turns out that it was a faulty oxygen sensor apparently. They also said that the spark plugs I fitted were the wrong ones but I ordered them from euro car parts with my number plate typed in and the correct details came up for my car. The car seemed to run exactly the same as before I changed the plugs, still with the other problem so I don't see how they were affecting the car. I will check the part number and see if they are correct. Does anyone have the correct part number? Any way, hopefully this is the end of the problems. Thanks for all the help and input, much appreciated.
  • Replies 56
  • Views 10k
  • Pretty sure I pulled the small pipe off the turbo intake (rubber hose with spring clip) and unbolted the larger breather pipe that goes next to the filler cap. That gave me enough movement in the pipe
  • Are your Spark Plugs 50,000 miles old, or have they already been replaced?
  • This tool to remove the coils:  http://www.amazon.co.uk/Hazet-1849-7-Ignition-Coil-Remover/dp/B001C9ZC2O/ref=sr_1_2?ie=UTF8&qid=1416999331&sr=8-2&keywords=ignition+coil+remover   This to
Do you mean the Spark Plug Numbers.?
  (Many Motor Factors get the Cross Reference Wrong, and supply the wrong Plugs.)
For the OEM.  03c905601A
(Some Skoda dealers have 03c905601B)
http://www.partsbase.org/parts/vw-03c905601b
NGK PZFR6R  (5758)
 Check that yourself,
i do not use them, i get DENSO from Euro Car Parts.
SKJ20CR-A8#4
(3371#4)
http://spareto.co.uk/oe/audi-03c905601a
http://eurocarparts.com
Edited by goneoffSKi
To help others can you lets us know which plugs you brought?
I bought the denso plugs Part No.: 408778820 on euro car parts. Cant seem to copy and paste a link on here so you may have to search that on the euro car parts web site.
If they supplied you with DENSO SKJ20CR-A8 (3371)  then you got the correct ones.
EDIT
408778820 is the right ECP no,
if they handed over the correct ones, there should be no problem.
Then I did get the right ones. I asked for them back but stupidly forgot to collect them when I picked up my car.
Hi!!
Sorry to change the subject slightly but nath vrs i notice it says your in rugeley.
As i am in the town of dreams that is rugeley aswell i just wondered if you still had the car?! :)
