Problems removing 1.9tdi pd sump pan
So yesterday i went out starting a service on my octavia changed the air filter, oil filter, fuel filter and drained the oil when i went to replace the sump plug i noticed that the thread had all came out and once putting the new sump plug in it will not tighten. I was pretty annoyed by this :(
So I decided to change the sump.. After removing varouis bolts it would not come off after further looking around i noticed that they are four up the side of the flywheel area 2 which can be accessed and another two which can't the two i couldnt access i decided to get a hex socket too with the ball on the end thinking this will be able to get them out but not it has just rounded the inside of the bolts i now have no idea what to do anyone got and suguestions?
Loosing the will to live with this sump atm.
Edited by Sk8erjm
hellicoil or tap to larger size  someone somewhere (can't remember) does oversize plugs   try e bay
