Tow phones connected via Bluetooth?
Hi to all
Does anybody know if you can connect two mobile phones at once via bluetooth?
I have the 2012 skoda superb estate.
Thanks in advanse
Nope.
On some setups it's possible to have one device feed music to the radio via bluetooth while another is connected as a phone.
ok cheers
The separate music device pairing is possible with the newer 3c8 035 730 a/b/c/d bt modules. And most modules can pair with up to three phones simultaneously although as indicated, each can only actually connect as a phone one at time.
How do I delete old phones paired?
By resetting the bt module to factory settings using the setup menu on the head unit (or by vcds on the bt module itself).
My late '11 built Superb will handle a connected phone and an iPad in Voice Navigation mode (better then the fitted Columbus, imo).
Edited by Mayor of Newark
