Recommendations for a Candy white Fabia
I'm after a bit of advice for products for the Furby as it is white what are the best available for this, I do tend to go from product to product but would like to nail down the best for the white vrs many thanks
  • Replies 65
  • Views 4k
  • NorthernMonkey
    NorthernMonkey
    Perfectly fine, just make sure you use a panel wipe to remove any oils or fillers before applying your sealant. CarPro Eraser or diluted IPA will do the job.
  • So a work friend of mine recognised the vrs had been cleaned and challenged me on a 5 year old black Volvo C30 these are the results using the sonax NPT [emoji106] quality product many thanks for the
IMO sealants are best on white, loads to choose from. I've used & can recommend Jetseal 109 & FK1000p
Have you used a de-iron on it, I bet you will be surprised about how much contamination will show up. White is a pain for showing up Tar as well.
Edited by NorthernMonkey
Just had a look on CYC at the 2 recommended they've got some great reviews [emoji106]
I used iron x yesterday and was
surprised how much was showing on the bodywork, after
washing it again after the iron x I used a clay mitt and was really happy on how good the paintwork looked!
You won't go wrong with either of those sealants. You could if wanted add a wax over it to add some gloss, but that's just personal preference.
How often do you rewax or reseal usually?
This will help me to suggest the best product for your car
White cars benefit more from an application of Sealer, as this will bring out the refectivity more on white paintwork
Fortunately sealants tend to last longer ..apart from some very high end waxes.
If you want the maximum durability, then a ceramic sealant will be best, but can be difficult to apply for a novice
How durable is the sonax couldn't find a review how it holds up.
Up to 6 months
The key to that durability is the preparation though
I can help with that if you want
Just PM me
I would say I wax once a month , as for sealing I'm a novice to this but looking into keeping the car looking good for longer
You will need to totally strip the car paintwork of any previous product
Polishing will enhance it further, then wipe down with IPA or other degreaser like Panel Wipe or Car Pro Eraser
Then apply the Sonax or sealant as instructed
You can then top up the sealant again after a few months
If youre not confident enough, I can help
Many thanks to the speedy responses some great products on here proves how good this forum is! I'm confident in decontaminating the car as I found out yesterday. I'm slowing building up the OCD armoury in cleaning products
Good one
Let us know what you decide to apply
Enjoy what ever you use, Jetseal & FK are very easy to use. Easy on & easy off.
White diamond glaze by poorboys shines amazing on my candy white.
^^and sonax on top?^^
Sonax BSD I hope you mean
I meant the BSD, missed your link to the hybrid stuff.
Could the hybrid stuff not top the glaze too?
I wouldnt ........As it needs bare paint to adhere to
Just use the BSD as a topper every few washes
Is it ok to polish before applying a sealent then?
White and Silver cars - i always fall back to FK1000P.
Cheap and versatile - but very durable. Great on alloys too by the way!
Not used Jetseal 109 - but again heard good things and super easy to buff off  :thumbup:
Yes it is
BUT
Polish contains oils which must be removed before the sealant is applied..Thats where degreasing products come in
Yes it is
BUT
Thanks Chris.
Intending to reseal my Candy White Yeti Oct half term. Did it when new in March with AF toughcoat so thought about due ready for winter.
Plan is to snow foam and wash, Iron X and remove tar spots. Then going to use AF tough prep.
Last time I didn't polish but have some Autoglym Super Resin polish in the garage so thought I would polish next.
Then degrease as you advise and then apply AF tough coat.
Normally apply Sonax BSD very three or four washes.
AGSRP is heavy with fillers, a very slight amount of abrasives.......and a slight amount of sealant
TBH.....I would get some 'proper' polish or a cleaner product...like DodoJuice Lime Prime...
...then apply your sealant...no need to degrease then as the Lime Prime will do that for you
