twin rear fogs
What do I need to wire both rear fogs together, do I need bulb plus holder or just the wire.
Do you have LED or normal tail lights?
Edited by Black_Sheep
For the LED lights the bulbs and wiring is in place - just need to recode using VCDS and cable. Details here:
http://www.briskoda.net/forums/topic/299424-octavia-iii-vcds-adaptations-tried-and-tested/?p=3567267
A list of VCDS owners is here:
http://www.briskoda.net/forums/topic/224376-vcds-owners-map/
Not too sure about normal tail lights but I'm sure someone will reply soon.
Because the BCM is expecting to see 1 21w bulb on that channel. When it sees 2 of them one of 2 things will happen, it will throw a bulb warning light and shut the channel down to protect it, or you will damage your BCM.
If you want to go ahead and invalidate your warranty with a bodge job by all means wire them together.
The correct solution is to do the coding for the second fog light channel.
Sent from my HTC One_M8 using Tapatalk
Havent got access to vcds so was hoping to wire them together, not found anybody near to me with vcds.thanks for letting me know about damage I could of caused, notsure why you think Iit would be a bodge job though
Contact Andyvee, he lives not too far a way, Top bloke, did mine for me
