Mil Light & Vcds
My mil light and epc came on, checked brake lights as sticky they were ok, then first the epc went off and then the mil light.
I decided to scan fault codes with vcds, first problem was vcds did not recognise can bus using auto detect so I set manually to Skoda Fabia 2 and it connected,surely it should have auto detected?
Fault code showed:
Address 01: Engine        Labels: Redir Fail!
   Part No: 03E 906 023 B
   Component: SIMOS91 1.2l 4V     1291
   Revision: --H04---    Serial number: SKZ7Z0G4355786
   Coding: 0000071
   Shop #: WSC 13765 790 00000
   VCID: 1E39C0A1CAACF49
4 Faults Found:
16705 - Engine Speed Sensor (G28)
            P0321 - 008 - Implausible Signal - Intermittent - MIL ON
             Freeze Frame:
                    RPM: 0 /min
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: -48.0°C
                    Voltage: 11.32 V
17796 - Control Module Malfunction - DBW Throttle Monitoring
            P1388 - 008 -  - Intermittent
             Freeze Frame:
                    Bin. Bits: 00000000
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0000
18088 - Reset-Resistant Limp-Mode Active
            P1680 - 008 -  - Intermittent - MIL ON
             Freeze Frame:
                    RPM: 0 /min
                    Voltage: 11.32 V
                    Bin. Bits: 00000001
18011 - Internal Control Module
            P1603 - 008 - Failed Self-Test - Intermittent
             Freeze Frame:
                    RPM: 1792 /min
                    Bin. Bits: 00000111
                    Bin. Bits: 01110010
                    Bin. Bits: 00000100
Readiness: N/A
NOTICED voltage low at 11.32v  car running fine all lights out now. Any ideas?
Fabia MK2 does not use full canbus, so autodetect will not work. Most of the Fabia MK2 ECUs still use traditional K line diagnostics.
Try and clear the faults, take the car for a short drive and see what returns.
One fault can cause multiple errors to be logged.
P.S I know an old weak battery can trigger steering sensor warning light (which has previously done) yet despite being 7yrs old it cranks the engine over fast and starting has never been a problem altough lights do dim on tick over.
  • 2 months later...
Yes, i agree. You have to clear all errors and try to find out which one appears first.
