Looking for a bit of advice.
I had a small shunt that snapped the headlight mounts. Using the Skoda replacement light mount brackets I was pointed to here on the forum I now have a stable near side headlight. The only problem is the beam is a little lower on that side.
I know that the VCDS has to be enabled to adjust the beam pattern/range but is the adjustment manual or is is done using servos in the the light with the VCDS?
Planning a trip to Skoda in South Wales to get it done but want to know what to expect.
Paul
The VW method (so I assume the same for Skoda) is:-
1. Park car on level ground
2. Use VCDS to put lamp servos in "level" position
3. Manually adjust lamps
