cam sensor wiring
hello
A couple of weeks ago the fabia (2004 vrs tdi) was taking a lot of starting it would turn over a fair few times before it would start.
got the car plugged in and it said cam sensor signal intermittent
changed the cam sensor ( genuine from tps)  and had a quick glance at plugs and wiring
a week or so later ive got the same problem.
got the car scanned and it says cam sensor no signal.
the car has now also started cutting out when cold although no other fault codes have been recorded by the ecu.
has anyone had a similar problem or know of a similar problem
many thanks for any help
sam
this is the fault code it keeps bringing up
Double check the wiring. My crank sensor connector must have been goosed cause someone have botched a repair, but only showed the issue when weather turned.
Double check each of the 3 wires is locked firmly in place.
ive checked wiring around the plug and its had a new sensor. going to have to find time to uncover and check wiring to ecu
Also make sure the pins in the plug are tight, use a pick to close them up so they grip the cam sensor wiring as tight as possible.
Other thing it could be is the new cam sensor is faulty?
its now showing no signal to cam sensor and intermittent crank sensor signals which cause it to cut out .... it seems shes slowly dying
Have you checked the wiring and plug?
Any chance it's a faulty part?
wiring has been traced back from plug to ecu and all seems ok a continuity test shows all plugs and connections are ok..... still cam and crank sensor faults
I would suspect your sensor is faulty, you could check to see if it is getting a 5 volt supply, the only way to test the signal is with a occiloscope.
but what are the chances of 3 sensors all going faulty at the same time ?
It's probably best to get someone who can read live data so you can see both the cam and crank sensor working because they both work with each other so if one is playing up the other one can get up set so you could have a crank sensor fault .... Also I would not be ruling out a wiring fault as you will always see resistance down a wire aslong as it hasent got a clean break Init so wire with half of its strands snapped or damaged you would still get resistance on it when doing your wiring check showing its fine when it's not .... Only way to truly check is with voltage checks and volt drops ..... Hope that helps
can anyone shed anymore light on this issue as i have now bought the car and within a day im suffering the same issues :thumbdown:
Edited by leeroyp1
Check the quality of your earth connections, particularly the ECU, when I say check I mean take them off, clean them up, grease them up and reassemble. Don't just look at them.
Unfortunate buying a car with faults from a forum member, I guess Holmesie couldn't be bothered.
take it back and get them to sort it.
to be fair to holmesie he traded it in to a dealer and i bought it off them.
Unlucky, however the problems are fixable, you can get the dealer to sort it for nowt.
thanks for the replies.i have taken it back already and they have said the same as sam did.cam sensor fault code but sam has already replaced this.thats why im asking on here for a bit more help.
Dealers issue Mate, either dodgy sensor (s) or loom, sensors ain't pricy or hard to fit so tell em to replace the lot.
