Fault Code Advice - Octavia Scout TDi BMM
hi
This is my first post in the VCDS forum and hoping for a bit of advice please.
I'm hoping to resolve these faults myself (as much as is practical...)
I have a 2008 Octavia Scout TDi (BMM), recently noticed a hissing noise coming from centre of the dash.
Searching the MK2 Octavia forum suggested that the air con gas pressure is low needs regassing.
Got hold of Ross-Tech VCDS and ran a scan.
The scan revealed 4 faults which are listed below.
  • 01 - Engine
    • 3 glow plugs - open circuit
    • Cylinders 1, 2, & 4
  • 08: HVAC
    • refrigerant pressure low
I'm hoping that someone can advise on these faults and how best to go about resolving them.
My intention for the HVAC is to get it regassed - is this the best approach? Is there a recommended company near Crewe, Cheshire?
For the glow plugs - I'm open to any advice on how to approach this, as I'm not sure where to check first.
VCDS log below for the affected modules.
regards
Nigel
Sunday,21,December,2014,14:59:38:51648
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0
Data version: 20140905
VIN: TMBKE21Z988021087   License Plate: <XXXXXX>
Mileage: 191360km-118905mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72 76
VIN: TMBKE21Z9XXXX087   Mileage: 191360km/118905miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 SS    HW: 03G 906 021 AB
   Component: R4 2,0L EDC G000SG  1302
   Revision: --H07---    Serial number: SKZ7Z0G4592276
   Coding: 0000172
   Shop #: WSC 66565 257 00032
   VCID: 820B2BA9DDC6510E0D9-80D7
3 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 177911 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:00:28
             Freeze Frame:
                    RPM: 840 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 00101100
                    Temperature: 16.2°C
                    Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 177911 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:00:28
             Freeze Frame:
                    RPM: 840 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 00101100
                    Temperature: 16.2°C
                    Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 177911 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:00:28
             Freeze Frame:
                    RPM: 840 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 00101100
                    Temperature: 16.2°C
                    Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 AB    HW: 1Z0 907 044 AB
   Component: ClimatronicPQ35 120 0600
   Revision: 00120022    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 76E3C779010EFDAEB11-8023
1 Fault Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded - Intermittent
-------------------   FOR INFO   ---------------------------------------------
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0191
   Revision:   H16       Serial number: 2000K07A19050C
   Coding: E9827F0E0002022303
   Shop #: WSC 73430 790 00000
   VCID: 34673D7157F2AFBE4F5-8061
No fault code found.
Low refrigerant pressure can cause funny noises. Also looks like you have some duff glow plugs.
Thanks for the quick reply trundlenut.
I'll source a local air con engineer or garage to do the re-gassing.
regarding the glow-plugs.
how much are these and are they much of a job to replace? Prefer to use OEM parts unless advised otherwise.
If there's no pressure in the system then there must be a leak, you need to get it checked before trying to regas it.
Don't know the price of the glow plugs exactly, but they are probably £10-15 each. Bit if a pain to replace as they are under the rocker cover IIRC.
OK thanks - seems there's a local garage that specialise in air con (among other things) - AutoLock in Crewe - I'll give them a ring tomorrow - they are usually very busy but according to their web site can diagnose the problem before starting any repairs.
Is there likely to be any damage caused if the car is run until fixed?
Will give Skoda dealer a call re glow plugs - might buy one and replace it to see if the number of glow plug faults drops from 3 to 2.
The system turns itself off when the pressure drops. I drove around with a knackered compressor for about 5 months without problem.
