1999 feicier gearbox drain plug
Hi guys I've owned my fleicier estate for the last 9 years trouble free until recently . so now need a little help .I need to drain the gearbox on its 1300 engine but just can't find the drain plug .has. anyone got a photo I've looked in the Haynes man but still can't find it .I would be very grate full for your help
Hi adriane, welcome to the forums. You may get some help if you put your post in 'Classic Skoda Owners' rather than here. Good luck.
It's on the passenger facing side of the gearbox, almost directly below the driveshaft, if I recall you need a 19mm spanner to undo it
I can see a hex bolt is that it . ? cant see a 19 mil Or is it only possible to see when the car is up on ramps
Edited by adriane
OK will do cheers mate
You might be able to see it without jacking the car up, it's almost at the lowest point on the gearbox differential casing, from memory I want to say 19mm spanner but it may well have been changed for a different drain plug at some point in the vehciles life.
Ah yes, I've just looked through some of my photos, it is in fact a hex bolt, you will need a large Allen key to undo it, can't remember what size it is off hand. It's directly in front of the triangular lower gearbox mounting bracket on the passenger side just below the passenger side driveshaft.
Thank you I don't know the size either I hope my brother has got one .thanks again for replying so quick
