Speedo not working on 6 speed conversion. (RESOLVED)
The 5 speed box had s speed sensor on it I think, after fitting the 6 speed box the speedo now doesn't work either, as well as my power steering
Any suggestions?
Can maybe it be altered in VCDS to get the speed from the ABS sensors?
Edited by gfwc
PM Jase?
Not sure how I can help sorry. I fitted all wiring etc so never had compatability issues going to six speed. I thought speed came from the abs sensors to be honest.
Everything is all connected up, but no speed :( the car is 2001 if that makes any differnce to how the speed was done then. But I'm pretty sure it was on the gearbox.
Can VCDS tell it to get the speed from abs ?
Vcds might tell you if it's not seeing speed from somewhere. A full scan should reveal something.
Ps, mine is 2001 too but all my bits came from a 2004 Vrs so it lives as that car essentially
Speed can be taken from vcds if you go on abs and check live data from each wheel.
Spoke to darkside today, and they told me that they have done loads of these conversions, and on all of them, the speedo just worked even withoit the speed sensor on the box.
I think you need VCDS personally.  It should give more of a guide than we ever could as a group. :)
Is your power steering working now? Maybe we missed a earth when putting it back in?
No mate it's not :( I keep looking and looking for any problems but can't see anything. Checking every pipe and cable all the way from its origin to check for any possibilities but nothing.
Spoke to darkside developments today and they think it's likely to be an earthing problem.
I really do not know !
Tracked the wiring back?
Yes mate, no breaks
Yes mate, no breaks
Bit stumped on that one,
I even hooked the pump earth up to the negative on the battery and still Notbing.
New pump or old pump?
The pump that was on the car, which was new in 2008 and it's a 2001 car.
Did it have the damp foam membrane around it?
No mate. It did have some sort of silicone stuff slapped on the plugs though which seems like Itbwas there to prevent water ingress. Possibly done before the pump chsnge and it not fix the problem so then they changed the pump. ... Just a theory.
Plausible, does VCDS bring up anything with the ignition on?
Csnt find my cable :(
No power steering light on the dash though.
Steering was lighter on one side than the other wasn't it?
No, after testing it with the wheels on the ground, there is no power either side.
It does work however on the left hand side where I can move the wheel between about 5-10cm. So one tiny little patch where it works and that's it. It's really tough to explain.
I understand, there's nothing until you hit the sweet spot on the left then nothing after it.
Angle sensor failing?
hi! I have just finished my conversion today :D everything is fine, power steering works well, so u did some mistake, u should recheck cables.
I am really interested in speedo from ABS since the old gearbox had a speedo sensor and cable, but not the new one. Now i am trying to get the solution. I think i should overwrite the abs sensor code in VCDS, but i have not used it before.... so if you have any solution on speedo please write it here also :) thx
