Long-Interval Service Items - "Sprich zu mir"
Right, I've done some more work for you:-  EFF129 is 151mm long (and its diameter is 61mm and 55mm - larger at regulator end) - these dimensions equate to a bare filter element.   EFF234 is 161mm height (long!) and its diameter is 61mm and 55mm - larger at regulator end - these dimensions equate to a filter+regulator combo.
Note, picture of EFF129 shows it fully built up with separate regulator without quoting "only filter element", EFF234 currently has not got a picture!
Hope that helps a bit more, I'd expect EFF234 to cost a bit more than EFF129 - maybe check that and if so ties in with what I've written above.
  • Replies 86
  • Views 7.3k
  • As you're addressing more than one person it would be "Sprechen". You also wouldn't use "to me - zu mir" you would say "with me - mit mir".   So "Sprechen sie mit mir"   That's your German lesson
  • Sprich zu mir?   It's been a loooong time since I studied German at school, but that sounds remarkably un-German!  I may be wrong.   I'd at least examine spark plugs a lot more often than every 4
  • Was your Golf a Mk1? (Must've been, I think, Mk2s have plastic tanks)   Plastic tanks have been pretty universal for a long time now.
Thanks. Good stuff.
This article, from across the big pond, may be of interest to the wider Skoda owning community:-
http://www.agcoauto.com/content/news/p2_articleid/219
They are advising 60,000 miles for replacement of "Lifetime" fuel filters external to the fuel tank and 100,000 miles for same located inside the fuel tank (Apparently some of the Jap manufacturers do this nowadays, Basically you replace the pump and filter).
Let's hope ERWIN has got a procedure for Fuel Flow Test - last time I did a quick visit I didn't notice it.
I see from the BMW forums that they've got the same issue. One cheeky chappy on there suggested that with all these "Lifetime" fit parts and fluids, then there should be a lifetime BMW warranty to go with it. Sadly not.
N
Edited by Clunkclick
The E-mail reply from Skoda Customer Services:-
"Thank you for your email dated 27 January 2015 regarding your ŠKODA Fabia.
I have checked with our Technical Department and they have confirmed that there are no recommendations in the service intervals for the replacement of the petrol fuel filter, manual gearbox oil or power steering fluid.
If you would like to have these items replaced then your ŠKODA Retailer would be able to perform these tasks and charge you accordingly.
I trust this information has been of help to you, but should you require any further help then please feel free to contact me on the telephone number listed below.
Thank you once again for contacting ŠKODA UK Customer Services."
When I asked this question in response:-
"Thank you for your reply
One further question.
Do I  take it from the omission in  your response below that there is a service interval for the engine coolant. What is this ?
For your information, as far as I am aware, the cooling system on my contains the original factory fill fluid, which is pink in colour. "
I was told over the telephone that there is similarly no recommended interval for renewal of the cooling system fluid - (Haynes manual says the recommended interval is two years unless the long-life G12 (Pink)  is used)
I understand that Valvoline manufactures  VW's G12 and BASF helped develop it. interesting to see what they have to say.
Doesn't seem that the American forums have much confidence in the European Auto industry "Lifetime fill/fit" concept :-
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1069859
I'm now working on the assumption that all these items need replacing.
Anybody know what the labour hours/costs and materials costs would be for replacing:-
a). The manual gearbox oil
B). The power steering fluid
c). The G12 coolant
d). The fuel filter.
N
After a bit of a hesitant start and a bit of prevarication, my motor is now booked in with the main dealer for annual service, MoT and replacement of the Fuel filter and gearbox oil.
Hoorah !
Nick
Had the service done today.
They replaced the fuel filter and the gearbox oil and did the annual service. Fine. Total charge  fuel filter change and gearbox oil change £118 (Approx)(Labour + parts, ex -VAT).
Only realised when I got home they haven't done the MOT (Which they have done without fail for the last 9 years) and another first,  I got an engine management light come on  the way home.
That's going to have to go back.
Nick
Had the MOT done Wednesday.(Luckily they managed to extinguish the EM light in the Instrument binnacle).
Bad news came Wednesday PM when I got a phone call from the shop to say that their VAG diagnosis system had picked-up an EGR fault which they initially claimed required the valve to be changed for £350 + VAT
I made it clear that the car hadn't been having before the service any of the usual symptoms of a non-operative or coked-up EGR,  i.e. engine  stalling at lights, surging, engine momentarily stopping and restarting whilst in overrun which I clearly recall from the first time when I had the valve cleaned, by the same dealer, in 2011 (18,000 miles ago). I also pointed out that I'd done a VDCS scan on the car on Wednesday morning before I dropped it in to the dealer for MOT and its was showing nothing for the EGR.
They then said maybe it could be cleaned for £40.  I said no, don't do it. Let me have a look at it first.
Anyway, the first VDCS scan was done on Wednesday morning (before they had it for the MOT) and it showed NO FAULT ON EGR (Although there are a **** load of other electric faults:-
VCDS Version: Release 12.12.2
Data version: 20140212
Wednesday,25,February,2015,08:35:42:08693
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBDD46Y02357****  Mileage: 96060km/59688miles
 Address 01: Engine        Labels: 036-906-034-APE.lbl
   Part No: 036 906 034 DF
   Component:  MARELLI 4MV        5020
   Coding: 00071
   Shop #: WSC 25021
   VCID: 59B3E0EDC33887D6BC9-4B18
   TMBDD46Y02357****     SKZ7Z0B148****
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ASR.lbl
   Part No: 6Q0 907 379 H
   Component: ABS/ASR 5.7 FRONT   V20
   Coding: 00124
   Shop #: WSC 13765
   VCID: 428127814EAE240ECD3-5120
No fault code found.
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Y0 820 045
   Component: Klimaanlage        X0830
   VCID: F2E13741BE8E548E1D3-5120
5 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
            30-10 - Open or Short to Plus - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
            28-10 - Short to Plus - Intermittent
            41-10 - Blocked or No Voltage - Intermittent
            29-10 - Short to Ground - Intermittent
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 C
   Component: 00 BN-SG.           1S33
   Coding: 17418
   Shop #: WSC 25040
   VCID: 3B7F5A65294455C68E5-5120
2 Faults Found:
01598 - Drive Battery Voltage
            07-10 - Signal too Low - Intermittent
01054 - Power Supply Relay; Terminal 30 (J317)
            28-00 - Short to Plus
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 601 C
   Component: 02 AIRBAG VW51      0004
   Coding: 12338
   Shop #: WSC 13765
   VCID: 20458D09A0E2161EBB7-5120
No Faults Found
Address 17: Instruments        Labels: 6Yx-9xx-xxx-17.lbl
   Part No: 6Y2 919 880 B
   Component: KOMBIINSTRUMENT VDO V12
   Coding: 16442
   Shop #: WSC 25021
   VCID: 46893B916286182EE1B-5120
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 33 GATEWAY  CAN    1S33
   Coding: 00014
   Shop #: WSC 13765
   VCID: F0E53D49B082669EEB7-5120
No Faults Found
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6Q0 423 156 M
   Component: LenkhilfeTRW        V210
   Coding: 00140
   Shop #: WSC 13765
   VCID: 3973406D237867D69C9-5120
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 E
   Component: 31 Komfortgerát     0001
   Coding: 00067
   Shop #: WSC 13765
   VCID: 3D7B547D37505BF6B01-4AE6
   Subsystem 1 - Part No: 6Q2959802
   Component: 31 Tõrsteuer.FS TFK 0002
   Subsystem 2 - Part No: 6Q2959801
   Component: 31 Tõrsteuer.BF TFK 0002
End   ----------------------------
And this is the scan I got after I got it back from them with an EGR fault. Strangely, there was no  EM light in the instrument binnacle. I zeroed the fault codes and took it for a longish run. No EGR symptoms:-
VCDS Version: Release 14.10.1
Data version: 20150130
Sunday,01,March,2015,19:25:35:08693
Chassis Type: 6Y (5J - Skoda Fabia (2007 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBDD46Y02357****   Mileage: 96160km-59751miles
   Coding: 00071
   Shop #: WSC 25021
   VCID: 59B3E0EDC33887E949E-4B18
1 Fault Found:
16786 - EGR System
            P0402 - 35-10 - Excessive Flow - Intermittent
Readiness: 0000 0000
   Coding: 00124
   Shop #: WSC 13765
   VCID: 428127814EAE2431384-5102
   VCID: 72E1B7413E8ED4B1684-5120
3 Faults Found:
   Coding: 17418
   Shop #: WSC 25040
   VCID: 3B7F5A65294455F97B2-5120
1 Fault Found:
   Coding: 12338
   Shop #: WSC 13765
   VCID: 20458D09A0E216214E0-5120
No Faults Found
   Coding: 16442
   Shop #: WSC 25021
   VCID: 46893B916286181114C-5120
   Coding: 00014
   Shop #: WSC 13765
   VCID: 70E5BD493082E6A19E0-5120
   Coding: 00140
   Shop #: WSC 13765
   VCID: 3973406D237867E969E-5120
   Coding: 00067
   Shop #: WSC 13765
   VCID: 3D7B547D37505BC9456-4AE6
End-------------------------(Elapsed Time: 04:18)--------------------------
Just have to keep my eye on the fuel consumption and for any symptoms.
I presume that changing the fuel filter earlier in the week first manifested itself as a EM light and that when they got rid of that for the MOT that it popped-up again as an EGR fault. This could just be random electrical effect. Luckily I asked  the chief mechanic to clean out the plenum chamber (Done Wednesday) as I thought that may have been the cause of all the other electric faults I was getting - apparently not from the latest VDCS scan.
Nick
:rofl: at this thread
The whole things laughable, dealers are compelled under pain of penalty under the Control of Pollution/Construction and Use legislation to get exercised about non-compliance with Euro IV exhaust regulations ' cause a faulty EGR valve isn't quite hitting the target vis-a-vis CO and NO2 emissions, meanwhile the engine can be spewing out unburnt oil mist like a crop sprayer cause engine oil use limits, in worn engines, of up to 1 litre per 600 running miles are acceptable ! Derrrrr !
Eurobull**** !
Nick
The thread must live.
Two weeks after the annual service and replacement of the "Lifetime" fuel filter and gearbox oil and a couple of long runs, the new components have bedded-in.
I have to say it most noticeable that the acceleration on the car, especially on motorways, is now back to what it should be. The old fuel filter must have been so clogged that it was impeding flow at the top-end of engine operations, leaning out the mixture and raising the combustion temperature.
As for the gearbox, way smoother and now the synchro hubs are not intermittently sticking as they used to. It was reported on service that the gearbox had been losing oil at the shaft seals, so replacing the oil has temporarily fixed that as well. Though they are supposed to regularly check the gearbox oil level on normal services.
There is a slight occasional hesitation when picking-up the throttle after drifting through traffic,. which I suspect could be the EGR valve sticking. I'll have to scan again to see if the EGR  Fault code has come up again.
In short, I'd recommend people change these components for a better driving experience. Perhaps a good interval would be the same one as is used for the cam-belts now i.e. 4 years or 40,000 miles, which ever is less, rather than at 60,000.
Nick
Ah well, wrt the fuel filter, maybe - wife's car is over 103K on the original one, warmer weather coming and a car change coming as well sometime in the next few months, probably smarter to fit the new filter/regulator combo than chuck it in the bin after the car has been sold!!
If the wife's just pootling round town, then she probably won't "Taste the difference". But its, certainly noticeable on motorways.
If this "Lifetime" *******s, is as suggested on the American forums, a marketing gimmick, aimed at Fleet owners, in an  attempt to convince them that the true costs of ownership can be pushed to the right of the ownership timeline, then I don't want to play, even if it costs me a few extra quids. Whose to know, whether dirty, lifetime fuel filters, haven't been, at least,  in part responsible, on the early Fabia injection engines (And perhaps the later ones) , for a build-up of fine dirt in and around the injectors which allowed the injectors to leak raw fuel into the combustion chambers when the engine was off.  This in turn led to excessive cylinder bore wear and early demise of those engines.
Nick
