1.2 12v Fabia, won't start
The fuel gauge seems ok but i haven't took a trip to the petrol station yet to see how it reacts to £20 worth of decent petrol.
Coolant temp sensor is another one I'm going to try. Haven't unplugged it to check though.
  • Replies 151
  • Views 18.7k
  • sepulchrave
    sepulchrave
    Clean up the top off the broken stud with an angle grinder and MIG weld a big fat nut to it then brute force it out and repair the thread if necessary with a long or double short Helicoil insert, I al
  • No.1 Sparkplug out,  long thing down the hole onto the piston crown, turn engine until it's highest, that'll get you close enough. No need to lock for this check. (Much, much easier to turn engine wit
  • fairly sure this is Taylor 93s subject
Well I'm quite pleased with how the car is getting on. Just worked out my mpg and getting 35mpg. That's quite impressive to me, it's had a lot of heavy driving with a fuel cleaner in, driving in a lower high at higher revs getting the cat in the exhaust nice and hot.
Must be able to hit 40mpg no problem with light driving and longer journeys.
