Difficult starting when engine warm - what solution is the best?
For me, this happens when it's summer and when the temperatures are above 20 degrees, when it's winter I have no problem when I drive a little longer and then when the car is 20 to 30 minutes, he does it like this, after that it starts normally Skoda Karoq 2020 1.6 tdi 115 hp
  • 3 years later...
Hi all
I'm having the same problem, 2008 fabia 1.9tdi, hard to start when warm.
Nothing showing on my obd reader
Fuel filter changed
Coolant temp changed
Crankshaft sensor changed
Fuel pump / feeder in the tank changed
Fuel pump relay changed
Egr removed and all cleaned.
What's the chances , try a new battery or starter????????
Just don't get this at all.
Great car, love 1.9tdi
I would only suspect a battery if it was struggling to turn over. This is probably more associated with intake temperature being incorrectly read. Not sure if that engine has a separate inlet manifold temp sensor, so more likely to be the MAP (Mass Air Pressure) sensor ( I don't think the diesel uses a MAF - Mass Air Flow).
On my Octavia Mk1 with a 1.9 litre tdi engine, this was a common problem. The reason was that, when warm. a certain cranking speed had to be acheived before the next step in the starting process could procede.
When cold, any crank speed is allowed.
The major cause was an old battery that could not produce enough current to acheive minimum cranking speed. Less commom reasons were corrosion of the ends of the starter motor cable or starter motor problems.
Ask someone to use jump leads from their battery next time you have the problem. Or swap out the battery.
Sorry for the late feedback.
I'll give it a try,
I'm thinking it could be the tandum put as this is a common fault with these engines,  saying g that . There's 205k on the car, love these engines.
I'll give it a try,
Tandum pump#
I had a warm start issue on my BKD, mine was the cam position sensor.
Thankfully it occurred when I was about to do the cambelt so it was easier to fix with the belt and idler off!
Already changed it mate.
Still no good.
Belt due at 220k
I think that Pikpilot has hit the nail on the head.
There is another way you can diagnose it, wait for the weather to be cold enough for it to have the cranking problems every start, that weather is probably already with us.
Take the battery off the car, take inside in the warm and charge overnight, or just charge enough for the charging current to drop then disconnect and leave it in the warm.
Fit the warm charged battery to the car the next morning and start it, if it starts instantly then you know the problem is the daft cold start algorithm.
Resolving the issue requires you to further test the battery, the connections and the starter wiring, do you buy a new battery or replace the starter?
3rd option is to have someone reflash the ECU to remove the nonsense lines of code, one of the great things about the PD engines is their ability to start in 1/4 turn even when the battery can barely turn the engine over,.
I need to rethink the above, the problem is when warm, maybe the jump leads are the best way.
Edited by J.R.
Always starts from cold.
It's o ly hard to start what the engine is warm, I'm.fittung a tandum pump tomorrow,  I'll keep ya posted..
It's only hard to start what the engine is warm
That is exactly the scenario I described above for a failing battery. When the engine is warm it is a common problen for your engine series due to not acheiving a high crank revs.
Why are you changing the tandem pump?
I had problems in the past with a vw and it was the same issue,  the tandum sorted it.
My battery has been tested and is 110%
I'll list all that I've changed.
Coolant temp
Crankshaft sensor
Fuel sender
Fuel relay
Tandum pump
Air flo meter
Egr & throttle body stripped and cleaned
I changed the tandum pump due to cutting out, fuel related, I'd tried everything else.
Still no further on. Wiring???
Wish it would just give up so I can put my finger on the problem
Check the cranking RPM when warm, I bet it is under the threshold for the nonsense software.
It's a stupidly high threshold in that the engine will appear to be cranking quite healthily, well any minimum RPM threshold for starting is stupid!!!
Thank you..
Heads melted lol
