Retrofit Bluetooth on a Spaceback S
Hi all!
Second post and a quick on - Looking at  a spaceback 'S' with a swing radio... Can you retrofit bluetooth to this?  or alternatively a head unit that is relatively cheap that will do the same thing?  any old links etc (cant find anything definitive after a look) would be great
I'm sure all spec Rapids come with Bluetooth as standard regardless of what headunit you have fitted?
I've just checked the Skoda website (which can often be wrong) and it seems that it is only from the SE upwards that you get bluetooth.
I think that was one of the reasons I bought an SE. The others being cruise control, the 105ps version with Greentech, Air-con & Alloys
I would normally go for a better spec but have seen a good deal on an S which has everything my wife needs for basic use bar the Bluetooth!...
I bought an S with the Swing and it has no Bluetooth, but I installed a Parrott kit so all is good :)
I highly rate their kits, the call quality beats anything I've used OEM-wise.
Agree Parrott is a good system. Strange the S has no BT [emoji15] wouldn't have taken Skoda much to fit it. Typical cost cutting [emoji19]
