Upgrading the radio to all the bells n'whistles
Straight to the point- which Skoda multimedia ICE units will fit the double DIN fitting on a 2010 Roomster SE?
My car has a Swing CD radio but can it be fitted with something with GPS/Bluetooth etc such as the Skoda Amundsen or similar?
Tim
In short yes. I've fitted a VW RCD310 DAB, although other units will fit.
I had no need for an inbuilt Sat nav, or anything more than one CD slot as all music is on my phone, but having the addition of DAB was good.
More or less plug and play with the addition of a foil DAB aerial on the windscreen.
Do you have a link to the aerial and was it Arsey to fit
Is coding required or just plug and play
You can basically fit any stereo you want. They will all work.
The Amundsen+ will give you sat-nav, Bluetooth (not all have the Bluetooth built in so be sure to check), DAB (again not all do so check), SD slot.
The Columbus will give you sat-nav, DAB (on certain models), SD slot and then for Bluetooth you need an extra module.
The Columbus has a larger screen and is generally a better unit but more expensive. The maps and software can be easily upgraded on the Columbus but not on the Amundsen+.
Do you have maxidot display?
Columbus:
Amundsen+
Phil
Edited by Phil-E
Here you go.
http://www.halfords.com/webapp/wcs/stores/servlet/ProductMobileDisplay?msg=&catalogId=10151&langId=-1&categoryId=165655&productId=907129&storeId=10001
No coding required. Aerial was easy to fit, just fed the cable in behind the A Pillar trim, behind dash into back of stereo.
I have a couple of teething issues with mine, although I suspect that is to do with the Parrot hands-free loom wiring vs the stereo.
It doesn't switch off with ignition which I'm sure is a case of swapping a wire over. It does switch itself off after 30mins if I forget!!
No maxi dot on mine
I would like to add that once I can find a binnacle cheap enough
Thanks Phil,
Maxidot is not fitted.
I want to rid myself of the GPS on the windscreen and upgrade the ICE at the same time, hence the question.
I just need to find a suitable unit and someone to fit it.
Tim
Thanks Phil,
Tim
I too was fed up with the sat-nav on the windscreen and cables running everywhere!
They are dead easy to fit. Just four screws, unplug the old one, plug in the new one and you're done!
You might not even need any coding doing as you don't have maxidot.
Phil
Is the trim around the radio missing
Sorry for the noob question I don't have the car yet to compare it against
Edited by malcster
Thank you,
I found a Columbus on Ebay and the seller will fit it -RESULT.
Tim
Can you take before and after pics please
Yes, and still is. I removed it to repaint in Urban Camouflage for weight saving ;) about 18 months ago and have never finished it :giggle: It does fit back as nature intended it though :thumbup:
Hi,
The Columbus unit is in and working. One feature that is missing is Bluetooth, how do I upgrade to this option?
More questions -
What is the purpose of the SD card, is it for map data?
I need travel maps of central Europe, is it worth buying the CDs offered on Ebay?
Tim
Hi,
More questions -
Tim
care to post some pics please
Hi,
I will post an image of the completed installation but it just looks like a Columbus in a Roomster.
Tim
Edited by Iblamethatcher
Good point I posted without thinking
Just being nosey thats all
Probably going to go down the 310 route as I'm not bothered about nav just dab plus its only leased so trying to keep the costs down
Unless anyone has any other suggestions to what sets will fit a brand new roomster
A definitive list of compatible sets would be nice
Edited by malcster
Now that the image has been posted, is there any chance of my queries being answered?
More questions -
Tim
Ive been doing some digging as Im thinking of a similar addition to mine. You need a seperate Bt module, seen them on ebay this afternoon but didnt take note of the price. I searched ebay for skoda columbus and found the modules. Also seen a mdi module which looks like you can plug your phone straightin to it using the data port on your phone but this may be over kill due to the bluetooth.
Not sure if maxidot is needed though. Im only guessing but would the sd card reader be for music files?
I think the SD is for music does it have 2 slots
Did you have to fit anything else to make the columbus work or was it just straight plug n pray?
You have to add a separate GPS aerial unless you don't want it to work.
And
There is no Bluetooth, you need a module.
Tim
Hi,
More questions -
Tim
The SD card can be used to either play music directly, or as a means of loading music onto the in built hard drive. The maps are stored on the hard drive also (different partition) so not related to the SD card.
The discs for sale on ebay are copies. There's a genuine V12 maps disc for sale in the classifieds section (mine).
going to plump for the 510 dab unit from VW i know the led is red
just not sure if they are all the same shape (i know the bolero has 2 different shaped units
and if the canbus is the same or it will turn itself off after an hour
