Octavia mk2 single door central locking
Just recently got car and seems the anti hijacking single door is activated. Driving me mad! I have the maxi dot, can I deactivate or is it a job for VCDS?
JJ
Yes you should be able to deactivate through the Maxi-dot.
Do you know where I can find instructions?
JJ
Tried the manual but all it says is can be activated by dealer?
Am I missing something?
JJ
JJ
Yes, you probably are. Looking in manual under Maxi-Dot. I changed the setting on my MkII FL vRS using the Maxi-dot. Page 25 in my owner's manual. It's under Comfort or Convenience, I forgotten which.
settings -> convenience -> door open -> automatic -> turn off "auto close" to disable anti-hijacking.
I don't think you can do it in the older (earlier) models via maxidot.
I have 55 plate elegance with full maxidot, but cannot change this.
I will double check as I have same issue, but am pretty sure I checked the whole menu.
^^^^ This.
I think is is only possible to adjust anti hijack on maxidot from Face lift onwards. It's certainly not possible on my 2006 L&K, so VCDS needed for the OP's 2005 model I'm afraid.
Can do it on my prefl 08
Must have been before face lift then. Maybe 2007.
Definely can not do via maxidot on 05 plate. The options are very different. Thanks for everyone's help
JJ
cant do it on my06 vrs with maxidot. Its a VCDS only option for me
Both mine have the options for changing single or global central locking, and anti-hijack functions. 54 plate and 08 plate pre-FL.
Interesting to note, too, that the settings can be made different depending on which of the two key fobs is used.
Mike
Can you remember how you did it on your 54 plate? Mike.
I've just checked again and cannot find the option.
You haven't enabled yours via VCDS have you? I see you have the kit.
Cheers.
Tony
Well, that's a mystery.
All I have is Main Menu - Set up -
                                                      Time
                                                      Winter tyres
                                                      Language
                                                      Units
                                                      Lights and Vision
                                                      BACK
Boo Hoo.
